I put the front suspension from a 77 f100 under my 67 to get the disc brake set up. If I now upgrade to power steering what mismatches will I have other than steering column length I have read about? I have the power steering box from the 77 and a donor Saginaw pump.
New to the group so thanks in advance.
Thom
Power steering conversion
Re: Power steering conversion
You'll need the steering arm from the dent as well. I'm not sure on the drag link, (if there is a difference between the manual versus PS) maybe someone else can chime in here with some more info.
Couldn't get the steering column from the dent?
Will be the best improvement yet on your truck!
