My 72 F100 at idle.
Forum rules
Videos are only allowed in the Video Gallery forum....not in a post in any other forum. Videos posted to any other will be immediately moved as needed. One video per thread, please! Nothing allowed of an adult, political or religious nature. For further rules and how-to's, click here.
My 72 F100 at idle.
Hey gang, here is a quick video of my f100 at idle. The fuel pump dies at the end. It runs but isn't pumping so I guess I will have to tear in to it tomorrow.
http://www.youtube.com/watch?v=jCSOBrwdS18[/video]
George
72 F100 SWB
398W stroker
72 F100 SWB
398W stroker
- Freightrain
Re: My 72 F100 at idle.
Sounds nice.
Is it me, or does it look like your key is in the accy position? Run is usually at about 2 o'clock. Yours is at 10 o'clock. Am I whacked out or what?
Bump'n along.
It could be in the wrong place I don't know lOL. It is straight across 3 and 9 with the key out. When you turn it to run it is at the 4 and 10 position and to start it is at the 5 and 11 position. I don't know where it is supposed to be, just always thought it was normal.
George
72 F100 SWB
398W stroker
72 F100 SWB
398W stroker
- Freightrain
Well, originally they are up/down when key out. Not a problem, just seemed odd and thought you had a unique switch.
Bump'n along.
What is funny is I would probably have a hard time and be fumbling around then if it were in the stock position. I never would have thought it could be moved.
George
72 F100 SWB
398W stroker
72 F100 SWB
398W stroker
I forgot to mention too that I got the fuel pump going again. The outlet line came loose at the AN fitting and the pump lost it's prime. She is all fixed now and hopefully at the end of the week I will have it washed up and get a better video of it and try and take some video while driving.
George
72 F100 SWB
398W stroker
72 F100 SWB
398W stroker
- Joshpow
Nice ride. Sounds great. The key is definately pointing wrong, but hey, it works. I am curious about engine mods done. I like the sound at idle. It is a little rougher idle thanmy 302. I plan to cam mine soon, so I want duration/lift ideas.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
http://www.cardomain.com/ride/2972100
71 F-100 Custom SWB
02 F-250 Stroke
I wish I would have went with 2 chamber flowmasters, the lope would have sounded better. I have the 3 1/2" exhaust dumped right in front of the back axle and it kind of all drones together and it is deep. Here are all the specs on the motor.
351 windsor stroked to a 398
forged aluminum flat top pistons / 11:1 compression ratio
main girdle
quick fuel Q950 dp
super victor intake, ported and matched to heads
trick flow high ports / ported and polished / 2.08 intake / 1.60 exhaust
solid rollers
1.6 harland sharp roller rockers
valve stud girdle
2" primary full length headers / 3 1/2" collector
CSR electric water pump
msd pro billet dizzy
msd 6al digital
The cam is a comp cams 286R on a billet core. The specs on the cam are:
248 @ 50 on the intake
254 @ 50 on the exhaust
.621 lift
18* initial and 36* total
Powermaster 140 amp one wire alt. (best thing I have done yet)
I also had to get the moroso alternator bracket to drop the alt low enough for the belt to clear the water pump.
We are hoping for 500hp to the wheels but I don't know with the c6. Should be close to 620-645 at the flywheel. If it ends up not being enough to get the truck in the high 10's I am going to put the 200 shot on it. I need to do the rear first before it makes it to the strip. I also have the original cam which will eventually go back in it once I get the money to get a 4500 stall but that thing was 279 @ 50 on the duration and .692 lift.
main girdle
quick fuel Q950 dp
solid rollers
valve stud girdle
msd 6al digital
.621 lift
George
72 F100 SWB
398W stroker
72 F100 SWB
398W stroker
- 1967AceStroker
Thats a damn nice truck you have there. I like how it sounds, can't wait to see more of it.
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
- AK F100
Very nice. If you want to go to Flowmasters next, what are you running now?
GPBFD Pyro Maniac
Daily Driver: 1974 F100 4x4 (ride'n on 8-Luggers) Build in progress
1997 F-350 Crew Cab 4x4, 7.3L Diesel SOLD
Pile-O-Parts: 1968 F100 - 2WD Shorty SOLD
Looking for a new project 57-60 Ford Truck
Right now it is 3 1/2" from collector back through dynomax race bullets and they turn down right in front of the rear axle. I like the way it sounds but it is a little too deep and the lope of the cam is kind of hidden from the exhaust being muffled under the truck. I would like to put 3 1/2" 2 chambers on it and have it exit at 45 in front of the rear tires. The truck lopes enough that you can see the truck rocking but the sound isn't there. Although as you walk around the truck certain spots end up not being mumbled as much.
George
72 F100 SWB
398W stroker
72 F100 SWB
398W stroker
- AK F100
Nice truck and sounds good too. I'm sure the video doesn't do it justice.
GPBFD Pyro Maniac
- flyboy71
Hey since he's moving within 2 miles of me he has no excuse now not to swing by someday and disturb my neighbors.
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
LOL that's too funny but true. We are so anxious to move. I still have alot of work to get the truck back together and I don't think I am going to get it back together in time for the ford nats.
George
72 F100 SWB
398W stroker
72 F100 SWB
398W stroker
I like it! Very nice
