Rear tire rub?
morganater
Rear tire rub?
Post by morganater »
Both of my swb f100s have 295/50/15s in the rear and they rub the inside sied of the tire on the side of the bed or whatever is down there. Is this really really bad? I can't tell when driving but c an see where it hsa been rubbing. I am thinking about putting on some 315/60-15 drag radials. Will these be terrible, and not even fit?
1969 f100 swb ranger 460 - parting out
1968 f100 swb 429 - decking out
94 Jeep I6 Back-up vehicle
reppin' AK
heep70
re: Rear tire rub?
Post by heep70 »
I am not sure if the grag tire will be worse, but it sure would suck to blow out a tire while going fast. Maybe you should consider tubbing the wells.
My tires did the same thing on my jeep when I was 4xing. One of the nobs grabbed the edge of the inner well skin and peeled a small piece up. That was enough to put a small slice around the sidewall of my tire. I ended up buying a rim with a shallower backset to get the tires further away from the inner fender well.
Greg
1971 F250 "Highboy". SOLD to "Highboy_Firefighter_71"
2000 Subaru Outback limited.
2000 F250 4X4 PSD SuperDuty Crew.
2010 Polaris 800RMK Dragon 155"
2013 Polaris Pro 800 RMK 163"
1980 Built Toyota "Trail Rig".
My last 1971 "Highboy" pics
CACWBY
re: Rear tire rub?
Post by CACWBY »
What is the rim width and what is the backspacing? 295's - even 315's should be oK but will probably require maximum backspacing, and a width of no more than 9" or 9.5"
I have 9.5" wide with 5" Backspacing and 275/60/17, and just enough room to know I could probably go to 295 and not rub.
I imagine you have 10" wide and 5" or less backspacing.
Trevor Rush
magnethead
re: Rear tire rub?
Post by magnethead »
What backspacing are you using? It would be a wise idea to tub the fenders or move the tires further out. Don't use wheelspacers, i've heard horror stories about those. Has the truck had a Drum to disc conversion (i'd imagine it had drums stock)?I wouldn't be surprisd if that did it, disc brakes are slightly thinner than drums, and can make the tires ruub, depending on axle and bed alignment. Is it only on one tire or on both rears? Check that the axle is on center, and the same with the bed. The axle may have slid sideways on the springs.
