The Blasphemous 1968 Fordillac
- kilog55
need to take the cap off as well as the home made side steps...which whatever hit it also damaged the stake pocket support cause the PO bolted it into them, kinda sucks but anyone know what color this may be? i see the one pic on the forum header is the same or very close in color with a white roof.
69 ranger gauge cluster
472 caddy motor
ever see these door panels before?
472 caddy motor
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
- cowbay
Re: The Blasphemous 1968 Fordillac
I am a fan of the high performance mod with the air cleaner cover flipped over.
"If it can't be fixed with a hammer, then it is an electrical problem"
69 Ford F100 Ranger 390 3spd with overdrive
63 Chevy Impala 327 with 4spd. In the family since brand new. Over 280,00 miles
- kilog55
old school cheater mods
- Joe Kriston
Cadillac, motor----why not?....
Those door panels are homemade---not bad really...The black and chrome trim piece was about an inch and a half bigger all the way around than the padded or metal door panel that came from the factory...
This is the point...I'm....talking about everybody! I'm talking about form! I'm talking about content! I'm talking about interrelationships! I'm talking about God, the devil, hell, heaven!!!! Do you understand???? Finally!!!!
- kilog55
i see, this is originally a cali truck, going by the stuff left in the truck like ins cards etc the PO had a 74 DeVille im guessing this motor is out of that car, since the 472 was the standard motor for that car it also had the turbo 400 trans, but it definitely doesnt sound like a ford .
plan on doing the motor up and possibly dropping the truck if i can find the right 8 lug wheels
makes me wonder whats under the tweed on the panels, probly steel id imagine
- flyboy71
I like the battery center console. Nice touch!
-Jeff
1971 F-100 240 straight six, 3 on the tree (parted out)
1972 F-100 302 auto trans, pwr steering, pwr brakes (under construction)
"Things are more like they are now than they ever were before" Dwight Eisenhower
- Joshpow
Make a nice one. Kinda like you no caddy motorvation for a ford. A GM project on the other hand!! Good luck.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
http://www.cardomain.com/ride/2972100
71 F-100 Custom SWB
02 F-250 Stroke
- kilog55
so far its been reliable, the PPO drove it from cali to here, the exhaust manifold to steering box clearance isnt the best its pretty close to touching, hoping a set of headers will cure that.
- yeager351
A local guy here has been running a wicked 500+ inch caddy in a Dent side for years. He uses 460 headers with some kind of exhaust flanges welded on. These Caddy's make killer street power.
- kilog55
yes they do its all low end power to, im gonna get a set of headers fabbed up like that once i get money for better heads and other mods.
