55 mph rpm?
1970F250
Post by 1970F250 »
update: i looked at my tag and it says 3.54. don't know where i got 4.10 from :hmm:
Steve
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
CJ,s 67 F100
re: 55 mph rpm?
Post by CJ,s 67 F100 »
Ok Here's your new rpm's
3.54 X 55 X 336 Div by 33 = 1,954rpm's
jor
re: 55 mph rpm?
Post by jor »
i have a 390 with a c6 and 4.10 gears and im at 2300 rpm at 65 mph.
Gee, that seems awfully low for 4.10 gears! My 3.50 rear end delivers about 2,500 RPM at 65 mph. Seems as though yours would yield 2,300 or so. Are you sure that rear end is a 4.10?
jor
1970F250
Post by 1970F250 »
1970F250 wrote:update: i looked at my tag and it says 3.54. don't know where i got 4.10 from :hmm:
:yt: i really don't know where i got 4.10 from :dk:
if the equation says 1,954 but my tach says 2300 does that mean my tach is off or that my tag is wrong and i have different gears?
Steve
binder56jd
re: 55 mph rpm?
Post by binder56jd »
"Sell crazy someplace else. We're all stocked up here" — Jack Nicholson, As Good As it Gets
now serving #235
"the only way to believe in the American dream is to be asleep"--GC
How much easier it is to be critical than to be correct. - Benjamin Disraeli
1970F250
Post by 1970F250 »
that one says 2345 so that sounds better
Steve
CJ,s 67 F100
re: 55 mph rpm?
That calculator gives 1982rpm. I came up with 1954. Your tach says 2300 so check your tire height again, measure it across from side to side and chock the front and jack up the rear end. Do this on a flat surface and be safe. Then put it in neutral, mark the bottom of the tire and the bottom of the drive shaft and turn the tire one full revolution and count how many turns the drive shaft turns. 4 to 1, 3 1/2 to 1, 3 1/4 to 1 what ever and then you'll have a better idea if your rear gears are correct with your axle tag
binder56jd
re: 55 mph rpm?
another not so published fact- in relation to analog speedometers- law allows for them to be +/- 10% from the factory- law enforcement is aware of this- so cj's method is a good one- also the 4-wd calculator is assuming everything is new - no wear etc. jd
now serving #235
1970F250
Post by 1970F250 »
i'll do that tuesday and let you guys know what happens.
Steve
kani73
Post by kani73 »
I am not sure what RPM I am at going 70 (no tach yet)but I know it is winding out pretty good. Enough I dont want to take it any faster. I have a 302 with a 3 speed. Not sure what rear end yet. Just got the truck last weekend.
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
kani73 wrote:I am not sure what RPM I am at going 70 (no tach yet)but I know it is winding out pretty good. Enough I dont want to take it any faster. I have a 302 with a 3 speed. Not sure what rear end yet. Just got the truck last weekend.
Compare the numbers on your VIN tag (on the driver's door) to the codes posted here:
http://www.fordification.com/data-1970.htm
The axle code will tell you what it came from the factory with....which of course means nothing if a previous owner has replaced it.
kani73
Post by kani73 »
Will do that tomorrow. I am lucky because I know the original owner. He the father of a friend of mine(who i bought the truck from) Thx
