1971 F250 CS Dana Swap
captchuck
Post by captchuck »
Gents- I have this 71 CS that came to me with an International Harvester Dana 60 rear posi/4.10.
I was thinking of swapping it out for a Ford Dana 60 from a 73 F250. Any tips on taking on this endeavor? Currently this rear seems a little wider- I will need a source for the spring perches and brackets for the shocks.
The Ford unit also has its drums frozen on pretty tight. I have not removed the axles yet to see if I can free them up- but if there is a trick to this- please let me know!
Thanks. :help:
Lee
Re: 1971 F250 CS Dana Swap
Post by Lee »
Hi,
Sir,... not to sound like an "arsh-hole" but I have to ask "why" do you wish to swap axles?
Is the current one giving you troubles?
If not,... then I would probably leave well enough alone.
Lee
captchuck
Post by captchuck »
My spindles are pitted, and it is making the oil seals fail quickly. This time I polished them and filled the pitts with JB weld. I suppose I can wait and see if it holds up. So that is the reason. Plus I picked up the '73 Dana 60 just in case.. So I was going to take it apart and start the process.
Thanks.
1972hiboy
Post by 1972hiboy »
I can see the benefit of changing back to a ford axle because of the ease in installation right? but a 73 axle is going to need to be modified to fit in your truck anyway since the rear of the frames are wider than the 72s, so, it really doesn't matter so much now if you find a ford axle or not because your going to have to cut and weld to make it work. you might as well contemplate any rear axle at this point or go look for a correct time period axle that will just bolt right in. :hmm:
Rich
1973 f350 super c/s 460/c6 22k orig miles
1972 f350 srw crewcab special 390
1972 f250 4x4 sport custom 390fe Red
1972 f250 4x4 custom 360 FE " Ranger Ric"
1972 f250 4x4 custom 84k og miles 390
1971 f250 4x4 sport custom 56k og miles. 360
1970 f250 4x4 428 fe hp60 205 d60
Dont eat yellow snow.....
stacerbob
Post by stacerbob »
captain where are you located?
captchuck
Post by captchuck »
Located in SW Connecticut.
Bill Ramsey
Post by Bill Ramsey »
captchuck wrote:My spindles are pitted, and it is making the oil seals fail quickly. This time I polished them and filled the pitts with JB weld. I suppose I can wait and see if it holds up. So that is the reason. Plus I picked up the '73 Dana 60 just in case.. So I was going to take it apart and start the process.
Thanks.
Um, speedi sleeves are the cure for worn oil seal surfaces. I use them all the time.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
1962 Fairlane 500 Sports Coupe
VW Sandrails
Honda ATC's
36' Diesel Pusher for roughing it.
captchuck
Post by captchuck »
Thanks. I looked into those- they don't make them for this rear axle size. Bummer!
