1969 F250 4x4 Highboy 7/9 rubicon
MaxKlinger
Re: re: 69 F100 Ranger(lots of pics) project
Post by MaxKlinger »
AlleyCat wrote:The broken part of the turn signal switch is what cancels ( turns off) the signal after you turn the other way.I did see a kit to repair this problem in ( I think) the NPD catalog.If not try LMC or Mac's.The other options are replacing the switch or remembering to cancel the signal after you turn.
Clay, I have this exact problem. I looked on NPD, couldn't find the kit. Someone posted a link to a company that makes new switches, any idea who they were? Remembering to cancel the signal gets old fast (especially when the arm droops by itself when you hit holes in the road).
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
AlleyCat
re: 69 F100 Ranger project(many new pics 11/18)
Post by AlleyCat »
Tony, Mac's , LMC and Dennis Carpenter all list turn signal switches for our trucks.Check prices because they vary. :)
Clay
72 F100 4x2 Custom,289, C4 " Slow Ride "
70 F250 4x2 Ranger XLT , 360, C6 "B52 - IV"
96 F150 4x2 XL, 300, E4OD, daily driver
" Professional Wrecker Operators - We Pull for America "
Manny
Post by Manny »
Man it's looking good your truck seems to be untouched :wink:
1971ford
Post by 1971ford »
well i am finding more and more PO changes as i tear down, but nothing major.
update-i found alot of surface rust in the door after i took the door panels off. its because there is no fuzzies or rubber to keep the rain out of the door and the truck sat for so long.
here is an inside view of the welded trim holes which i will be drilling out.
carpet which i removed
only found little rust on drivers floor pan
i should have another update at the end of this weekend. we are going to the junkyard to hopefully pick up a bench seat that was there which only had one small tear, but it was green. so i will re-upholster it.
-Ryan
1971ford
re: 69 F100 Ranger project update 11/22
Post by 1971ford »
i just did some thanksgiving shopping :D and picked up this at the junkyard. it only has one small scuffed up section on the drivers side. Since its not in bad shape, i wont have to tear it apart and refoam it, ill just get a NPD 180$ cover.
wont be put in for a long time, but i cant wait until it does go in :D
-Ryan
1971fordsdad
Post by 1971fordsdad »
Once again I get no credit. His brother and I pulled this thing and carried it out for him. At least he paid for it. Only $23!!! Score!!!
1971ford
Post by 1971ford »
i think everyone knows im too young to go into a junkyard, and im always mentioning you grabbing parts from the junkyard trucks. sorry master
-Ryan
1971fordsdad
Good boy.
wt4speed#2
Post by wt4speed#2 »
I hope you two are on separate computers . If not does the laundry fairy do the refereeing.
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
1971ford
Post by 1971ford »
lol
hes at hard work at work
im at home
-Ryan
1971ford
Post by 1971ford »
woohoo
i got a compressor, air nossel, impact gun, air ratchet, and accesories :D primairly to take fenders/everything else off the the 69 and to paint the trucks. i havent even gotten a chance to use it yet :( . but i will tomorrow. im sure ill find plenty of stuff to take apart.
anyways,
i havent gotten any work done to the 69 this week because im working off the truck every day (perfectly fine with that, its actually fun and interesting and i learn lots of welding/metal stuff).
I talked to the PO's daughter about the paint and stuff and she said she would look for pictures of the truck when they got it. im really looking forward to seeing those pictures! I also found out some history, like the story of how the truck once was stolen and the police then found it.
this weekend i should have a good amount of work done to the truck.
well thats it. i will ask if i can borrow the pictures of the truck when it was new so i can scan them and put them on here so all of you can see. she did confirm the "baby blue" (sky view blue) and white colors but didnt know where they were on the truck.
thats it for now :D
-Ryan
so ryan did you take the outer door panel off or the inner door panel? if you took off the outer one id like to see how you did it.
1971ford
Post by 1971ford »
i took off the one that has the waves on it which the armrest and stuff is on.
what is a inner and a outer door panel?
thanks
-Ryan
that is the inner door panel.you took off then i was thinking of that dent on the passenger door panel. i had thought maybe your dad had gotten a new outer skin for the door and you guys were replacing it. i just wanted to see how someone would do this. i thought it would be interesting to see.
1971ford
Post by 1971ford »
oh ok.
it doesnt sound too hard, but seems getting a new door would be easier.
seems like you could just unbolt and take the guts out of the door, grind the outer panel off and weld a new one on. id rather get a new door though.
-Ryan
