1969 F250 4x4 Highboy 7/9 rubicon
yeah i was thinking a new door would be easier. i am still wondering about how to get a old door skin oof another door and put it on another door with out messing up the wrap around part.
1971ford
Post by 1971ford »
another pittyfull update..
well i havent gotten alot done at all, since the shelter over the truck had collapsed on the poor trucky. anyways, we got it back up minus the tarp today. i managed to sqeeze some work time in on the truck. I removed the horns, the jack holder, horn relay, batter, battery tray(trash, its rusted through), 10 lbs of gunky stuff, and ... umm thats it :oops:
BUT, I took the horns, and jack holder off so i could get the inner fenders taken off once the tarp is back on the shelter and so i could clean them really good, and paint them with the few cans of gloss black rattle can i just bought. im going to strip, primer and paint every thing in the engine compartment except the engine. ( all brackets and stuff too).
I hope to get the heater/ ac set up stuff pulled too soon. well thats it really.
oh and anyone know what this stuff is? its sprayed all over the underside of the hood.
-Ryan
1971ford
Post by 1971ford »
this is how i decide what needs to be black and what needs to be ford blue:
-Ryan
AlleyCat
re: 69 F100 Ranger project -little update(11/30)
Post by AlleyCat »
Undercoating or sound deadener. :)
Clay
72 F100 4x2 Custom,289, C4 " Slow Ride "
70 F250 4x2 Ranger XLT , 360, C6 "B52 - IV"
96 F150 4x2 XL, 300, E4OD, daily driver
" Professional Wrecker Operators - We Pull for America "
1971ford
Post by 1971ford »
im guessing sound deadener, since the cab is so quiet!
-Ryan
mljjones67
Post by mljjones67 »
oil
layedout72
Post by layedout72 »
So is that would that little hold down on the driver side is for?!? The Jack? Never would have guessed it.
I can send you a picture of my engine bay if you'd like. It's solid black, flat black, but will be gloss sooner or later. The motor is black as well. When I put in the stainless loom, and the chrome enginer accessories (filter/valve covers) that should bring out some color in there.
Mooosman
Post by Mooosman »
Get that truck a pinion seal for the rear end.
Please?
That axle's nasty! :lol:
Nick
1972 F-100 Custom SWB
cghstrojan08
Post by cghstrojan08 »
Looks like oil junk.
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
1971ford
Post by 1971ford »
thanks mooosman,
ill have my dad translate and get that taken care of when the truck comes apart.
there should be lots of stufff happening soon, since school is out for christmas break :rock:
i havent done anything recently to the truck, since im studying for Final Testing.
-Ryan
AlleyCat
Post by AlleyCat »
It's too uniform to be oil.Besides that it is coated as far forward as I can see.If it was oil it would start about 18" from the front.The fan wash would push it rewards. :)
Clay
69bumptruck
Post by 69bumptruck »
An old undercoating with a nice layer of dirt on it (hence the tan color). My old Fairlane had the exact same thing under it. Hard to get off. Kinda like tar.
David, owner of:
1969 F100 SWB (restoration in progress)
http://www.cardomain.com/ride/2317125
1971ford
Post by 1971ford »
i plan on scraping the stuff off. its ugly. hopefully it wont be too hard to scrape off.
-Ryan
1971ford
Post by 1971ford »
it feels so good to update :woohoo: :drive: :yip:
after a month, today i have been able to get alot of progress!!!!
heres what i did and found- i took off most of the front clip, found that the rear frame had been torched off, a wire mess under the bed, a bunch of bondo on the bed, and i found out that the original color scheme was white roof, skyviewblue upper portion, white bottom portion.
this is just a wee-bit of what was in the cowl drain :eek:
now for the bad news :( . look what the PO did to install the cheby bumper :cry: =
the tubes from the hitch go and weld onto the frame, just before it is cut
more bad-
MOREerreerererer bad! (that would be bondo, which is on the bed, and goes for a long length :cry: )
i will update frequently now that i have something to work under
-Ryan
AlleyCat
re: 69 F100 Ranger project -big update (1/21) bad findings!
Post by AlleyCat »
Looking good Ryan :thup: The worst I've seen is where the village idiot went bonkers with a gas axe.A good welder can fix that pretty easy.As far as the bondo and butchered wiring goes things like that are to be expected when working on a truck that's crowding 40 years old. :)
Clay
