1972 Ford F100 Project.
Re: 1972 Ford F100 Project.
First thing this morning used the angle grinder with wire wheel to knock back the rust on the rear leaf springs and components. Then I hit it with Phosphoric Acid. That was it for the day, got too hot, maybe prime first thing tomorrow morning.
Primed the rear leaf springs. Have to wait 24 hrs. before top coat.
Coming along for sure!
Put the first coat of semi-gloss black today, will do the second coat tomorrow. Then I wait for my leaf spring bushings to come in from the states, mIght be another week or two for them to arrive.
- Manny
Looking really good! Googled that and figured out the tremclad deal. That stuff holds good. Used kbs coatings and it’s great stuff too. Liking the way this is coming along.
- Bullitt74
I remember using Tremclad on an old swing set when I was a kid...painted over the rust after sanding the scale off, and it held up better than the original factory finish. This truck will never get this abuse it had in its first life, so that Tremclad topcoat will outlast all of us
Looks great! keep posting your progress
- wndsofchng06
Nice work!
The rear leaf spring bushings ( Energy Suspension 4.2139G ) arrived in the mail this morning. Installed them and put the leaf springs back on the truck.
Amazing how much an improvement you made. Great work!
Took the angle grinder with the wire wheel to the rear axle today and then brushed on phosphoric acid. Tomorrow hope to get the primer on the axle.
- popeyes71
Looking good, your making some good progress!
- Jacksdad
Dude - slow down. You're making the rest of us look bad
Thanks everyone for the positive comments.
Primed the rear axle today.
