oil / fuel gage maxed out
Electrical and Wiring Forum Archives
fordman
Post by fordman »
it could be that regulator. it controls the voltage to the gauges.
fordman
Post by fordman »
yes there is a link to that page here somewhere. look in the site index for it.
fitzwell
re: oil / fuel gage maxed out
Post by fitzwell »
got one in mine...will check it tonight & let you know what / how to check. You are using a 69 cluster, correct?
As a metter of fact, i AM trying to keep up with the Jones'
Driving like Parnelli, Drinkin' like George
Dumptruckman
Post by Dumptruckman »
Step#1 Disconnect the wire at each of your sending units and check for voltage there with the ignition switch in the on position. If you find a pulsating voltage, your dash panel voltage regulator is working correctly.
Step#2 Disconnect the wire at the oil pressure sending unit and at the fuel level sending unit. Place the ignition switch in the on position and check your gages. If they are still maxed out, I would run a new temporary wire from each sending unit to the respective gage. This will eliminate whether you have a short in either wire.....
Dumptruckman
Check this website out....It may help you, it shows the factory wiring diagrams for Ford trucks.
http://www.fordification.com/wiring.htm
fordman
Post by fordman »
sounds like you put 12 volts straight to it with the other wire it should only have one hot from the regulator and a feed from the tank.
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Well, you might try a slight tweaking to the IPVR:
http://fordification.com/forum/viewtopic.php?t=9698
