#01 - Jan. 21, 2007
#01 - Jan. 21, 2007
What is this part? I need to know the specifics, not just the general. In other words, don't just say it's a widget...I wanna know the specific application and year (if it varies).
- 71 LONG BED
re: #01 - Jan. 21, 2007
Distributor hold down clamp for a small block, a 302 or 351.
Not sure what years it was used. 1971 for sure. I don't think it ever changed.
John Member #1549
71 F100 Sport Custom__________1967 F350 Gone, but not forgotten
- GT-Racer
I thought it really was a widget, thanks for ruining it Keith. No it is a dizzy hold down but I am not sure the years either. I know that is an early one.
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....
- rjewkes
Small bock ford Distributor holdown clamp from 1969-89.
fuelly.com
fuelly.com
- Sharkdance
I dont know what it is.......YET
But I dont think its a dizzy hold down. Way too heavy steel and waaaay too thick. Definetly not for an FE if it is.
fordman might be closer with it being a wheel clamp. But I dont know.
- 390Nut
It's a grease fitting for the left-hand muffler bearing for a `67 F450 heavy-half ton triple axle dump.
I've seen that item before, but, I think oldtimers is kicking in a bit (or maybe a very mis-spent youth is what's catching up to me) as I have no clue what it's for.
`69 F100 390 4spd driver
http://www.fordification.com/galleries/ ... ?cat=10251
Dura-Spark II Conversion info at:
http://home.comcast.net/~390nut/Dura-SparkII.htm
Pipes71 did once say, "bumps and bikes.. what a great combo!"
- ICEMAN6166
it is a distributor clamp,
not for an FE
it is an earlier one because its cast iron but it is for a 289/302/351W at the least, and if you are counting only the 67-72 trucks , would be the 1st year you could get the 302 so 1970-72 302 is the correct application.
not for an FE
http://fordtruk.com/forums/album.php?ca ... user_id=26
you can ford a river or stream and get to the other side, if you dodge it you will not, and if you drive a chevy to the levee it will run dry and the music will die.
- rjewkes
I was for sure that 69 was the first 302. I could be wrong on that though.
fuelly.com
fuelly.com
Well, I won't hold you to the correct years used on this one, but let's just say we don't have a winner....yet.
(Is it gettin' warm in here or is it just me?)
- AustinTom
Not yet!
And it's definitely a Ford truck part.
