#01 - Jan. 21, 2007
How's your Ford truck parts knowledge?
rjewkes
Post by rjewkes »
Axle spacer 69-75? just guesing now.
but it does look like my dizz clamp.
fuelly.com
ezernut9mm
re: #01 - Jan. 21, 2007
Post by ezernut9mm »
y block crankcase vent holddown? (i'm just guessing-never seen one before).
wanting to buy a mercury tailgate!
"the man who is swimming against the stream knows the strength of it".- woodrow wilson
turbocharged400sbc
Post by turbocharged400sbc »
dont know what size it is but it looks like the dizzy clamp on my 390fe which looks alot like the one from my buddy's 76 251W
1994 Olds 442 (425 cid-4 wheel drive-2 V6's) http://www.cardomain.com/id/94twinengine442 13.81 @ 98.2 MPH 1.9s 60's
68 F250 Camper Special 390FE/NP435/3.73D60
soon: 79 F350 disk brakes w/ 3.55 D60, pneumatic, 1750w AC inverter, Vector 1600w lightbar, 200A 3g alt, all a mobile gearhead needs
AustinTom
Post by AustinTom »
Well its not a 302 clamp i pulled mine off my truck to compare and it aint it
69 F-100 lwb 240 Np435
95 F-150 lwb 4x4
http://s110.photobucket.com/albums/n85/ ... type=local
trukcrazy
Post by trukcrazy »
Speedometer cable clamp at the transmission. :?
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
kknip
Post by kknip »
How about the dizzy clamp off a 429-460?
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
xxxtina63
Post by xxxtina63 »
I'm thinking fordman was on the right track. On the old F600's, rather than having a "solid wheel", didn't some have multi-piece wheels? I'm not talking about a split rim, but one that has the one piece center w/face that bolts to the axle, and a separate rim? It looks kind of like a 5 spoked wheel when all is mounted. The spare tire has the rim part on the tire but no center. The 2 pieces are clamped together with a thing like what's pictured. The large curved inside of the piece fits on a "knob" on the end of the center's spoke to prevent rotation while the tooth on the end clamps into a groove on the outer rim piece.
Maybe I'm wrong and waaay off, but that's my best guess.
71 LONG BED
Post by 71 LONG BED »
It definitely is a dizzy clamp, just what motor it's from is the question. It looks almost exactly like the one I have on my 302. The only difference is it isn't cast iron. It looks machined.
It is a distributor hold down clamp from an FE block. :?
John Member #1549
71 F100 Sport Custom__________1967 F350 Gone, but not forgotten
Image Image Image
Re: re: #01 - Jan. 21, 2007
kknip wrote:How about the dizzy clamp off a 429-460?
WE HAVE A WINNER!! :woohoo: :hd:
Yes, this is the distributor hold-down clamp for the 335-series engine, the 429/460.
It's very similar in appearance to the small-block hold-down clamp, which is why it was throwing you guys off. In fact, after 71 LONG BED's guess of a small-block clamp, it got me to wondering, so I made a special trip all the way across town to the shop in order to pull one for comparison...(and believe me, I got :roll: from my wife for doing so!)
Here's a side-by-side comparison shot. The small-block clamp is on the left, the 429/460 version is on the right:
As you can see, they are virtually identical...except that the 429/460 piece is nearly twice as thick. However, they each use the exact same bolt. :D
So kknip: did you know this or was it a guess, based on what everyone else was saying? Doesn't matter, as your answer goes down in the logs as the first correct answer of the Ford Truck Trivia contest. :thup:
Dropped 68
Post by Dropped 68 »
Distributor hold down for a 460, as far as I can tell.
71 LONG BED
I realized it wasn't cast iron, but I wasn't sure if all of the small block clamps were cast. They do look as though they are interchangable.
I almost had it. :doh: Next time! :thup: This is fun, when is the next one? :pop:
John Member #1549
Image Image Image
Sharkdance
Post by Sharkdance »
O.K.
I have to admit. That one had me.
I agree that it looked like a dizzy clamp. But Ive never seen one that stout.
Sharkdance
70 F250 2WD 360/C6
Dropped 68
:oops: didn't see that it had been answered already on page 2
kknip
Post by kknip »
Actually,I did guess,I knew it was a dizzy hold down clamp,after everyone was guessing the different series of engines and had not mentioned the 335 series,I figured it had to be it.Although I did think of the Cleavland family,they did not appear until the dents were made. :D
You knucklehead!
65 Mustang
tynall44
Post by tynall44 »
dist hold down :2cents:
