New Accel HEI, but O forgot what wires go where.
xMAJORx
Post by xMAJORx »
Installing a an Accel 52000 series.
When I removed the engine, to swap in the new one, I forgot what wires go where on the coil. Anyone have a color coded diagram or a pic that I can reference?
Or if you know of the top of your head.
Oh by the way: 71 F100 390FE.
Check out my Ford at Car Domain.
http://www.cardomain.com/ride/2358125
layedout72
re: New Accel HEI, but O forgot what wires go where.
Post by layedout72 »
is it the point eliminator kit? if so, its got brown red and green. red is hot, green is negetive, brown is engine block ground i believe. if its not the point eliminator kit, i dont know.
xMAJORx
Post by xMAJORx »
Im not really worried about the Dizzy wires, just the wires that come out of the firewall. Ya, know one goes to my electric choke, one goes to temp unit, and the others go to the coil somewhere right? Which positive which negative?
68F250
Post by 68F250 »
Coil + is Red/Green stripe (the coil - came from the old dizzy)
Temp. sender is Red/White stripe
Oil sender is White/Red stripe
Electric choke, not stock, your on your own for that one.
Barry
xMAJORx
Post by xMAJORx »
I have the oil, and temp unit wires installed. I just need the other ones. What generally goes to the coil besides the dizzy wires?
kid
Post by kid »
Coil gets from factory Dizzy to negative and ignition red/green stripe to positive. There is no negative wire in the system as the one attached to the negative coil terminal is going to a place more negative than the plus wire so it is marked so the coil does not get reversed and fries.
