sheet metal question???
kaptnkaos
Post by kaptnkaos »
Hey Guys,
Does anyone know if the sheet metal used for door skins is the same gauge as the floor pans ???
I have a couple of crunched doors and was wondering if I could use the sheet metal from them to cut a couple of patches for the floor-pan.
Thanks again...
KaptnKA 8) S
Washington...The land where rust is like the family pet...Ya learn to live with it and clean up after its mess... KaptnKAOS
"Olde Skool" '68 Ford Bluebird short bus
"FRODO" '68 F-250 Camper Special project
Ranchero50
Post by Ranchero50 »
Feels about the same. Only 'problem' is the floor panels are stressed (bumps and ridges) to make them striffer.
Jamie
kaptnkaos
re: sheet metal question???
Post by kaptnkaos »
I just need to patch a small flat area near the kick panel and door seal...
probably a 4"x4" square would do it...
KaptnKA 8) S
rjewkes
Post by rjewkes »
if its flat there then it may work.
fuelly.com
i think you could use it. it would be better than using a beer can or something like that.
4th effie n counting
Post by 4th effie n counting »
well a beer can wouldn't rust :lol: what about using a section of bed floor? wouldn't it be a bit more stout ?
67 F100 240 I6 3spd now gone :(
1971 F250 LWB FE power by FORD
kaptnkaos
Post by kaptnkaos »
Hey 4th effie n counting,
yeah, bed floor would probablybe stouter, but I don't have a spare bed to cut up... but, I do have a junk door...
Tha's why I was askin' if it was heavy enough gauge to patch the floor with.
KaptnKA 8) S
F100builder
Post by F100builder »
It'll work Kaptn. If the door is really junk, then cut your 4"x4" piece out of it and compare it with the offending 4"x4" piece cut from the floor. I'm betting it's the same. Did you know that Lowe's and Home Depot sell small pieces of flat sheet metal in several thicknesses? Just an FYI. :D
***edit*** I could say for sure as I have a junk cab (in about 7 pieces!) in my back yard and I could throw a set of calipers on it if you'd like.
Patrick
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
kaptnkaos
Post by kaptnkaos »
That would be cool F100builder...
I still have a couple of things to do before I get to that point...
I got the new turn signal switch from NPD yesterday...
Hopefully we'll get some decent weather so I can get it installed
Then I gotta get the rest of the lights workin'...
For some reason when I plugged my camper in none of the lights worked...
I also need to mount the rear stablizer and hitch receiver...
I want to use the truck and camper next month...
KaptnKA 8) S
SteveC
Post by SteveC »
check to make sure you have power going back to the plug in for the camper...i know mine had power coming from the start sylinoid on the inner fender but that line was soo fraid i just unhooked it and did some thing else intirelly
I don't really care about brands Chevy Ford Dodge ...as long as it doesn't sound like two old dudes farting in a coffee can.
http://s169.photobucket.com/albums/u223/imabaka70/ Projects listed on the left side
WOOOT!! i passed my mechanics classes. Now working as a mechanic and waiting to go for my ASE certifications.
1967 f-100 4x4
1969/72 f100 351w EFI m5r2 5 speed
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
Kurt Combs
Post by Kurt Combs »
Kaptn,
For a 4x4 piece you could use just about any sheetmetal laying around. Of course, the thicker the easier it is to weld to, within reason. You should be able to "massage" any 4x4 piece into the correct shape with a hammer and a board or the jaws of a vice. Have fun.
Kurt
1972 F-250
kaptnkaos
Post by kaptnkaos »
Thanks for the input guys...
I need to get in there with a wire wheel and get the loose stuff off and see what I really have to work with...
I don't know how to weld yet...
I am seriously considerin' takin' some classes...
KaptnKA 8) S
wt4speed#2
Post by wt4speed#2 »
hey Kap,
I used an old inner fender to patch mine . And I was learning to use my new welder. Kinda looks like bird poop on a paper plate but they are in there. So I would think door skins would suffice.
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
Kurt Combs
Ok, starting to learn how to weld on sheet metal will be an interesting experience. Do you know anybody who can show you how? If you can't find a mentor nearby, practice on some old, clean sheet metal before you tackle the floor of your truck. I can give you some basic advice (I ran a mig many years for a living), 1) You must move fast or the weld puddle will disappear before your eyes. 2) You want your parts to fit together tightly or you will "blow through". 3) Cleanliness is critical. 4) If using a mig with gas, no wind allowed. All that said, if you have experience stick welding plate metal, it is completely different from welding sheet metal with a mig. Be prepared to go-like-hell so you don't create too much heat and have the previously mentioned blow through. Good thing about welding, you can usually grind it off and start over.
Kurt
1972 F-250
kaptnkaos
Post by kaptnkaos »
I don't even have access to a welder...
The last welding I had done cost me $150.
That was on my bump trailer...
possibly a whole 18 inches of arc welding bead (8 short welds)
and about 24 inches of oxy/acetaline cutting on the frame.
KaptnKA 8) S
