Please help with plug wires (routing, order)
Negative
Post by Negative »
Hey, I just realized I don't know what the hell is going on.
I finally got my engine ready to turn on, went to put the plug wires on and then it hit me.. ummm which one goes where?
I know the firing order, and thats about it.
I know the rotor turns counter-clockwise, but which is #1? I could get it from there i suppose, but I don't know which is #1 on the cap!!
I feel like a retard!
Help so I can start this thing please???
CWoT ~ Are you smart enough?
'69 F250 - Lunar Green (ewww)
Custom Cab - 2wd - 360 - C6 auto.
71PA_Highboy
re: Please help with plug wires (routing, order)
Post by 71PA_Highboy »
OK... the first thing you need to do is put #1 piston at TDC... ON THE COMPRESSION STROKE.
To do this pull the spark plug out of #1 cylinder. Put your thumb/finger over the hole. Turn the engine over until you hear escaping air, then bring it to TDC.
Next, take the Dizzy cap off and see which way the rotor is pointing. It is pointing to the #1 spark plug wire post location.
Starting there, put the wires on in same order as the firing order.
The timing will be close enough that is should start, and then time it from there.
hth,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 F250 4x4 (71) - OB - 360, NP435, D24, HPD60 4.10, D60,
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
Negative
Post by Negative »
Thanks! Yes that worked. More work than I wanted, but it starts and runs now so it was worth it! :lol:
rjewkes
Post by rjewkes »
Does this solve the problem in your other post too?
fuelly.com
Negative
Post by Negative »
nope. The other problem came up afterwards.
rjewkes
Post by rjewkes »
ok, sounds like you may be leaning out or it could be riching out. also are you sure you have it wired on the plugs correctly. 1-4 being on the pass. and 5-8 being on the drivers?
you probably do. i don't think it would idle too well with anything crossed.
fuelly.com
Negative
Post by Negative »
Yeah, I was worried about the firing order, but I triple checked that, it runs amazing until you hit the gas!
