Stupid Question: How to remove rear drums
oldschoolrods
Post by oldschoolrods »
Ok stupid stupid stupid question but I'm stumped. How the H#*( do you get the rear drums off. My 69 has 8 bolts on a hub type thing infront of the drum. I've tried taking those 8 bolts off but nothing comes off. How does this set up work? Please help before i get out the grinder. :twisted: :evil: :lol:
MudinMan4x4
re: Stupid Question: How to remove rear drums
Post by MudinMan4x4 »
Take those 8 bolts out..slide the axle shaft out... there a big nut holding the drum on (youll see it when you pull the axle shaft out) then pull the drum off let me know how it goes maybe I can get some pics for you
"Gas' Guzzler fer life" "Southern Pride""It's not what you buy it's what you build"
oldschoolrods
Ok, what can you use to slide the shaft out?
MudinMan4x4
it'a prolly on there with some kinda sealer should be able to pry it off when you put it back on besure to use some permatex or sealer......
oldschoolrods
no luck sliding it out even with the use of a hammer lol oh well i guess it will be going to the shop :(
