Transmission Links
Drivetrain-Related Internet Links and Resources
Moderator: 70_F100
Transmission Links
AUTOMATIC
TRANSMISSION IDENTIFICATION
AUTOMATIC TRANSMISSION TAGS AND LOCATION
TRANSMISSION PAN ID
TRANSMISSION PAN ID
TRANSMISSIONS BY MODEL/YEAR
C4 IDENTIFICATION & SELECTION
C4/C5 TRANSMISSION APPLICATIONS TABLE
C4/C5 TRANSMISSION SPECIFICATIONS
C4 IMPUT SHAFT CONVERSION
C4 TO AOD CONVERSION
AOD CONVERSION TXT FILE
5.0 FOX AOD REPLACEMENT
AOD TROUBLE SHOOTING
AOD TV CABLE LINKAGE AND RETROFIT
AOD TV CABLE ADJUSTMENT
AOD TV CABLE ADJUSTMENT VID
AOD/E/4R EXPLODED VIEW
AOD EXPLODED VIEW PDF FILE
AOD CLUTCH AND BAND APPLY CHARTS AND SPECS
TRANSMISSION FLUID LINE COOLER RETURN LOCATION
'66/'68 TRANSMISSION OIL COOLING SYSTEM DIAGRAM
'65/'66 SHIFT CONTROL MECHANISM DIAGRAM
REVERSE PLANET DISASSEMBLY AND ASSEMBLY PDF FILE
REVERSE CLUTCH PISTON DISASSEMBLY & ASSEMBLY OF SUBASSEMBLIES
AOD REVERSE CLUTCH INSTALLATION PDF FILE
C3 TRANSMISSION
C3, AOD, A4LD NEUTRAL SAFETY SWITCH
C3 FRONT BAND ADJUSTMENT
C3 & A4LD EXPLODED VIEW PDF FILE
C4 & C5 EXPLODED VIEW
C4 NEUTRAL SAFETY SWITCH ADJUSTMENT
C4 TRANSMISSION
C4 EXPLODED VIEW
C4 EXPLODED VIEW PDF FILE
C4 TECH OVERHAUL
C4 FRONT PUMP SEAL REPLACEMENT
END PLAY CHECK ON C4 VIDEO
MAKING AIRCHECKS ON FORD C4 VIDEO
C5 NEUTRAL SAFETY SWITCH ADJUSTMENT
C4/C5 W/LOCK-UP VIEW & PART NR'S PDF FILE
FORD 3 SPEED & BORG WARNER EXPLODED VIEW
FMX FORD PDF
FMX SHIFT KIT INSTALL PROCEDURE PDF FILE
C6 EXPLODED VIEW
C6 EXPLODED VIEW
C6 EXPLODED VIEW
ASSEMBLING THE FORD C6 VIDEO
ASSEMBLING THE FORD C6 TRANSMISSION PUMP VIDEO
C6 HYDRAULIC DIAGRAMS 1
C6 HYDRAULIC DIAGRAMS 2
C6 HYDRAULIC DIAGRAMS 3
C6 HYDRAULIC DIAGRAMS 4
C6 HYDRAULIC DIAGRAMS 5
C6 HYDRAULIC DIAGRAMS 6
C6 HYDRAULIC DIAGRAMS 7
C6 HYDRAULIC DIAGRAMS 8
C6 HYDRAULIC DIAGRAMS 9
C6 HYDRAULIC DIAGRAMS 10
C6 HYDRAULIC DIAGRAMS 11
C6 HYDRAULIC DIAGRAMS 12
C6 HYDRAULIC DIAGRAMS 13
C6 TRANSMISSION SCHEMATIC PDF FILE
C6 TRANSMISSION BRAKE KIT INSTALLATION PDF FILE
C6 VIEW & PART NR'S PDF FILE
E4OD EXPLODED VIEW
4R70W/4R74W-4R70E/4R75E VIEW & PART NR'S PDF FILE
E4OD/4R100 4 SPD OVERDRIVE VIEW & PART NR'S PDF FILE
4R70W & E4OD TRANSMISSION
AOD-E/4R70W & AOD FUNDAMENTALS
AOD-E/4R70W & AOD UPGRADES
UNDERSTANDING & CONTROLLING E4OD LOCK-UP DELAY SOLENOID
IDENTIFYING E4OD/4R100 SOLENOIDS
AODE / 4R70W TCC SLIP, CODE P0741 PDF FILE
4R70W/E - 4R75W/E SUN GEAR SHELL/PLANETARY/RING GEAR DIFFERENCES
5R55N/S/W SERVO PISTONS APLICATION & UPDATES
5R55N/S/W VALVE BODY BOLT INSTALLATION PROCEDURE PDF FILE
TRANSMISSION COOLER
B&M SUPERCOOLER INSTALLATION
AOD(E) TRANSCOOLER INSTALL
GORDS FORD HEAT EXCHANGER INSTALLATION
SHIFTER
1960’S FORD SHIFTERS
'65/'66 (AUTOMATIC) SHIFTER HANDLE REPLACEMENT PDF FILE
HURST BILLET PLUS SHIFTER INSTALL
HURST COMPETITION PLUS SHIFTER INSTALLATION PDF FILE
MUSTANG 111 ET 4SPD SHIFTER
‘05/’08 GT AFTERMARKET SHIFTER INSTALL
AUTOMATIC SHIFTER BUSHING REPLACEMENT
STEEDA LATE MODEL TRI-AX SHIFTER INSTALL
LATE MODEL MAC RACER'S CHOICE SHIFTER INSTALL
INSTALLING AFTERMARKET T-5 SHIFTER
S 197 SALEEN SHORT THROW SHIFTER BLOCK
S 197 MGW SHIFTER INSTALLATION
S 197 SHORT SHIFTER INSTALL
BELLHOUSING
5 BOLT VS. 6 BOLT BELLHOUSING PATTERN
C4/C5 BELLHOUSING APPLICATIONS
C4/C5 BELLHOUSING DIFFERENCES
CLUTCH, BELLHOUSING & LINKAGE INFO
C4/C5 BELLHOUSING PICTURES BY THE NUMBER
6 CYL TO V8 BELLHOUSING ADAPTING
LAKEWOOD 4.6 BELLHOUSING INSTALLATION
SIZES & DIFFERENCES
TRANSMISSION SIZE COMPARISON
OVERDRIVE UNIT
HONODRIVE OVERDRIVE UNIT
GEAR VENDORS OVERDRIVE
C6 Exploded-View Diagram
Variable Stall Control
TREMEC / BORG-WARNER
TREMEC TRANSMISSION TAG IDENTIFICATION PDF FILE
TREMEC/BORG WARNER/TTC TROUBLE SHOOTING
TREMEC 3550/TKO 5-SPEED SERVICE MANUALS PDF FILE
TREMEC TKO 500 & 600 MIDSHIFT CONVERSION KIT PDF FILE
TREMEC TKO INSTALLING TIPS PDF FILE
TREMEC TKO PARTS CATALOG PDF FILE
TREMEC T-56 SERVICE MANUAL PDF FILE
TREMEC T-56 REBUILD MANUAL PDF FILE
BW T-5 REBUID AND SERVICE INFO PDF FILE
TREMEC T-5 SERVICE MANUAL PDF FILE
BW T-5 TRANSMISSION DATA
BW T-5 IDENTIFICATION
BW T5 CUT OPEN VIEW
BW T-5 CABLE CLUTCH CONVERSION FOR CLASSIC MUSTANG
REBUIDING AND UPGRADING BW T-5
BW T-5 SWAP FOR CLASSIC MUSTANG
T-5 & TREMEC SWAP
AOD TO T-5 SWAP
FOX 5.0/SN95 AODE TO T-5 CONVERSION
TREMEC T-5 SPECIFICATIONS
TREMEC TKO SPECIFICATIONS
TREMEC T-45 SPECIFICATIONS
TREMEC T-56 SPECIFICATIONS
TREMEC 3550 SPECIFICATIONS
TREMEC 3650 SPECIFICATIONS
T-56 SIX SPEED INSTALLATION
TREMEC 350 FOR CLASSIC MUSTANG
SN95 AODE TO TREMEC SWAP
'66 C4 TO TOPLOADER 4 SPD CONVERSION PARTS LIST
T5OD 5 SPEED MANUAL PDF FILE
T-45 / TR3650 DIMENSIONS PDF FILE
TREMEC TKO SHIMMING PROCEDURE PDF FILE
TOPLOADER
MANUAL TRANSMISSION DIFFERENCES
TOPLOADER 4 SPEED DATA
TOPLOADER REBUILD STEP BY STEP
BUYING USED TOPLOADERS
TOPLOADER DIAGNOSING SHIFT PROBLEMS
TOPLOADER IDENTIFICATION
'69/'70 BOSS TOPLOADER TAG IDENTIFICATION
TOPLOADER IN LATE MODEL INSTALL
TOPLOADER TRANSMISSION MANUAL PDF
TOPLOADER RATIOS
3 SPD SHIFT LINKAGE & LOCK ROD ADJUSTMENT
FORD MUSTANG GROUP 6 MANUAL TRANSMISSION MANUAL PDF FILE
CLUTCH
CLUTCH TROUBLE DIAGNOSIS
CLUTCH WEAR SIGNS
CLUTCH REPALCEMENT BASICS
CLUTCH SERVICE AND ADJUSTMENT
CLUTCH PEDAL FREE PLAY
LATE MODEL, CHOOSING A CLUTCH
CLUTCH DRIVEN DISC & PRESSURE PLATE REMOVAL & INSTALLATION
‘64/’73 CLUTCH ADJUSTMENT
‘65/’70 HYDRAULIC CLUTCH CONVERSION PDF FILE
'69/'70 CLUTCH PEDAL BUSHING REPLACEMENT
MUSTANG 111 CLUTCH SWITCH ASSEMBLY
MUSTANG 111 STARTER CLUTCH INTERLOCK SELF ADJUSTING CLIP
MUSTANG 111 CLUTCH PEDAL ASSEMBLY
MUSTANG 111 SELF ADJUSTING CLUTCH COMPONENTS 1
MUSTANG 111 SELF ADJUSTING CLUTCH COMPONENTS 2
SCATTERSHIELD TO CABLE CLUTCH ACTUATION
’79 AND UP CLUTCH CABLE FIREWALL ADJUSTER PDF FILE
‘79/’93 CLUTCH PEDAL HEIGHT ADJUSTER KIT PDF FILE
‘94/’04 CLUTCH PEDAL HEIGHT ADJUSTER KIT PDF FILE
‘92/’03 STEEDA DOUBLE HOOK CLUTCH QUADRANT / CLUTCH ADJUSTMENT KIT
TRANSMISSION GENERAL
TRANSMISSION BY VEHICLE
ENGINE & TRANSMISSION SPECS
MANUAL TRANSMISSION DIAGNOSIS
2.3 AUTO TRANSMISSION SLIPPING PROBLEM
SPEEDOGEAR CHOICE INFORMATION
SPEEDOMETER GEAR USAGE PDF FILE
GENERAL TRANSMISSION INSTALLATION INSTRUCTIONS
CHANGING AUTOMATIC TRANSMISSION FLUID AND FILTER
ENGINE & TRANS RECOMMENDED TEMPERATURE
TRANSMISSION TRANSDOCTOR
‘74/’78 MANUAL TRANSMISSION CODES
’78 TRANSMISSION CODES
’77 TRANSMISSION CODES
’76 TRANSMISSION CODES
’75 TRANSMISSION CODES
’74 TRANSMISSION CODES
TRANSMISSION PAN ID
TRANSMISSION PAN ID
TRANSMISSION OVERHAULING TOOLS
VALVE BODY TECHNICAL MANUAL PDF FILE
VALVE BODY APPLICATION GUIDE PDF FILE
TRANSMISSION CONTROL SWITCH TECH TIP PDF FILE
SPEEDOMETER ACCURACY / SPEEDO GEARS
CONVERTER
TORQUE CONVERTER GENERAL INFO HOW IT WORKS
VARIABLE STALL CONTROL
TORQUE (STALL) CONVERTER SELECTION
CONVERTER TECH TIPS
TORQUE CONVERTER UPGRADES
RATIO, RPM, TORQUE MULTIPLICATION
FORD FINAL DRIVE RATIOS
TRANSMISSION RPM CHARTS
TRANSMISSION TORQUE MULTIPLICATION RATIOS
DRIVE SHAFT
DRIVESHAFT ANGLE
COMPANION FLANGES
DRIVESHAFT AND U-JOINTS
DRIVESHAFT AND U-JOINT SERVICE AND INSTALLATION
'65/'72 DRIVESHAFT DIAGRAM
BOSS 302 DRIVE SHAFT DETAILING
IRS DRIVELINE ALIGNMENT EN SOLVING VIBRATION PROBLEMS
LAKEWOOD DRIVESHAFT LOOP INSTALLATION
DRIVESHAFT & DIFFERENTIAL CHOICE PARTS INTERCHANGE
S 197 ONE PIECE DRIVESHAFT INSTALLATION
TRANSMISSION WIRING & VACUUM
MUSTANG 111 BACK UP LIGHT SWITCH
'94 MUSTANG 5.0 AODE DIAGRAM 1
'94 MUSTANG 5.0 AODE DIAGRAM 2
'94 MUSTANG 5.0 AODE DIAGRAM 3
'95 MUSTANG 5.0 AODE DIAGRAM 2
'95 MUSTANG 5.0 AODE DIAGRAM 3
'96 MUSTANG 4.6 4R70W DIAGRAM 1
'96 MUSTANG 4.6 4R70W DIAGRAM 2
'96 MUSTANG 4.6 4R70W DIAGRAM 3
'99 MUSTANG 4.6 4R70W DIAGRAM 1
'99 MUSTANG 4.6 4R70W DIAGRAM 2
'99 MUSTANG 4.6 4R70W DIAGRAM 3
'99 MUSTANG 4.6 4R70W DIAGRAM 4
'05 MUSTANG 4.6 5R44S DIAGRAM 1
'05 MUSTANG 4.6 5R55S DIAGRAM 2
'05 MUSTANG 4.6 5R55S DIAGRAM 3
OBD-II E4OD MASS AIR CONVERSION
5.0 ‘94/’95 CCRM PCM TRANSMISSION DIAGRAM
SN95 OD SWITCH RELOCATION
