Bootleg aftermarket awesomeness! show us what you got.
wordforge
Post by wordforge »
Okay, I'm not sure if anyone has started a topic like this before so I apologize if they have and i'm double posting. But I got the idea from the "big burtha" topic in the project updates board.
But here's the idea. I know that during the progress of most of our projects we've all seen some spectacular solutions to problems that were fixed with less than adequate parts.
perhaps some examples to let you all know what the hell I'm talking about.
aftermarket exhaust hangers
Sport Pedals
Custom mesh grill
you get the idea, i'm sure i'm not the only one with stuff like this.
If you are going to tell someone the truth you had better make them laugh otherwise they'll kill you.
- George Bernard Shaw
1971ford
Re: Bootleg aftermarket awesomeness! show us what you got.
Post by 1971ford »
good idea :D
is that exhaust laing on the rearend? :eek:
i cant think of anything crazy on my trucks though
-Ryan
My 4x4 came home from it's previous owner with some rather 'unique fixes' applied to it.
How about this one:
The MC's rear reservoir was capped off with an air-hose quick-disconnect which had been welded shut. The front reservoir had a flexible line attached to it via several homemade adapters.
Same truck. Guess the previous owner ran out of fuses, so he found something else to use....
...which I'm sure probably had something to do with the meltdown I found under the dash:
Different truck...this '67 was in a salvage yard. (Got some good rust-free doors and a sport bumper w/brackets from it.) I guess it's owner decided to mount some 6 x 9's in the dash....maybe with an air chisel? :doh: (BTW, note the 'cool' padded steering wheel...foam rubber and lots of electrical tape.)
The same owner then apparently took the same air chisel to the floorboard, to cut out a HUGE hole to stick a rod down through for a shifter when his column shifter broke:
One more. The PO of this truck converted his truck to power steering with a Saginaw box. When he found that the new box altered the angle of the column through the firewall, and that he didn't have the appropriate PS column firewall plate, he simply 'glued' it into place with a can of expandable foam. Guess he decided that since there was still some foam left in the can, he went around sealing up various firewall holes. :hs:
1971ford
Post by 1971ford »
hahahaha keith those are great ! :lol:
Did '67 have those in-dash speaker slots instead of holes :? Im not talking about those awesome new speaker holes but the factory one :lol:
-Ryan
wordforge
Post by wordforge »
1971ford wrote:good idea :D
No it's not, the bailing wire keeps it about 2" from the axle but it sure does come close
wordforge
Post by wordforge »
this has gotten me to wondering just what the hell the previous owners of our trucks were thinking when they did this stuff. all I can come up with is:
"beer money v.s. parts for the truck I go to buy the beer in."
best I can do.
FordTruck
Post by FordTruck »
Ok I got some thease are of my truck that I bought on Ebat and the guy said it was a good truck you know all that BS and when the cab swap started I found all this.
This My Professionally Installed Tranny. It Sarted Out With A 3spd On The Floor And In This Picture Was Afer They Changed It Over To Auto.
And Here's The Tranny Mount When I Got It There Were No Nuts On The Bolts
Also He Told Me There Was A Little Rust In The Floors But It Was Also Professonaly Fixed. All This Was Covered Up By Pices Of Intertube
And The Totally Awosme Battery Tray Fix
And The Dent Fix That Bondo Was Really Thick On Spot Was Almost Half Inch Thick And On The Bottom Of The Bed You Could See Where It Had Run Off The Bed A Dried Like That :lol:
The Rest Of Thease Are Of Custom Stuff I Found On My New Cab. The Story Behind It Is That The Guy Bought It From Told Me That The Guy He Got The Cab From Bought It Brand New And Took It Home And Put It On An International 4x4 Frame. Witch Is True Because I Have All The Recipts And Stuff From When He Bought It. Even The Orignal MO Tilte.
You Can See Where They Cut It To Fit The IH Stuff On The Tranny Hump.
If You Look At The Cab Mount You Can See There Custom Too.
I Guess The Had To Cut The Firewall For Something
And Were They Fixed The Neutral Saftey Switch
I'm Guilty Of This Rig Job :oops: I Made Some Temp. Cab Mounts To Set My Cab Back Down On The Frame. My Welder Really Sucks So They Don't Look Pretty But There Still Holding The Cab The The Frame Till I Can Get The Cash To Buy The New Mounts And A Better Welder.
"Flyin High On Caffine And Copenhagen" R.I.P Chris LeDoux
60 Mercury Comet
65 Ford Econoline
72 Ford F100 on 79 4x4 SWB frame
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
wordforge
Post by wordforge »
that battery tray fix is AWESOME! i should take pic of mine. the PO had it (the battery) held on by a bungie cord. I took it apart but I bet I could approximate it pretty simply.
the 3 speed shifter fix is pretty amazing too.
FordTruck
Post by FordTruck »
Some Of The Stuff People Come Up With Is :loco:
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
tybob81
Post by tybob81 »
I put a painless wiring kit in my 68 because all he fuses were taken out and replaced with cut off bolts!! At least all my lights woked an t didn't burn down on me before the resto. :lol:
1968 swb hydroboost, ididit tilt column, Saginaw p/s pump with F series serpentine, all led lights, Vintage Air and painless wiring. 393w, tko600. CV front suspension w/c5 calipers and gt500 rotors. Stock Flexomatic leaf springs with 01 CV 8.8, 3.90 gears and Auburn locker. Custom wood bed floor. Full frame off resto-mod.
wordforge
Post by wordforge »
that's freakin' amazing. I'm kind a shocked that your truck didn't catch a slight case of, " holy crap it's on fire."
FLATBEDFORD
Post by FLATBEDFORD »
From a '67 F350 that 71LongBed and I bought and scrapped together a couple years ago.
Did somebody say Bondo?
Somewhere I have a picture of a chunk of the Bondo and aluminum foil that was in that hole.
Steve
1970 F350 DRW Factory 9' Platform/Stake, 360, T18.
Passed on to new care taker July, 2013
My Photo Gallery
http://s115.photobucket.com/albums/n298/flatbedford/
fords rule
Post by fords rule »
wow i thougth my truck was bad when it had 2 really old autolite spark plugs and 4 close to new champions
my also came with fairly new biasply tires and owner didnt bother to put a wheel bering in it so one tire is toast :?
SteveC
Post by SteveC »
:eek: is that a c clamp holding the exuast together??
I don't really care about brands Chevy Ford Dodge ...as long as it doesn't sound like two old dudes farting in a coffee can.
http://s169.photobucket.com/albums/u223/imabaka70/ Projects listed on the left side
WOOOT!! i passed my mechanics classes. Now working as a mechanic and waiting to go for my ASE certifications.
1967 f-100 4x4
1969/72 f100 351w EFI m5r2 5 speed
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
FLATBEDFORD
SteveC wrote::eek: is that a c clamp holding the exuast together??
Why? Is that bad? :lol: :lol:
Steve
My Photo Gallery
