Post your 4X4 pictures HERE!!
Socal F250
Re: Post your 4X4 pictures HERE!!
Post by Socal F250 »
Thanks Manny, those are 235/85 16's......
1971 F250 Explorer 4wd
2006 E350 Adventure Van 4wd
Manny
Post by Manny »
Socal F250 wrote:Thanks Manny, those are 235/85 16's......
Dig it alot. :thup:
smokeyquartz
Post by smokeyquartz »
70short4x4 wrote:Thanks guys. I brought the rear up just a tad. The nose high look (even though it was totally level) wasn't doing it for me. Looked too squatty in the rear with the lowered wheel well openings.
I'm much happier with how it sits now. New trucks look good level. But I think these old trucks need a little bit of rake to em :)
Looks great as is. Love the simplicity of the exterior, but I find it irresistible to be the model for some modification project. :thup:
Socal F250
67mann
Post by 67mann »
:D makes me wish my project truck was a "High Boy"....nice stance and patina 8)
Socal F250
Thanks 67!! Having a great time with her.....
Lone Ranger
Post by Lone Ranger »
Socal F250 wrote:Image
I see you found the wheels you were looking for-much better :thup:
Kyle
Socal F250
Yes & Thanks Lone Ranger, they work perfect for the look I wanted.......
nath34
Post by nath34 »
My best friend...
Lee
Post by Lee »
Owned her 17 years.
Rebuilt everything that can be rebuilt.
Many Mod's,... biggest being adding the Advanced Adapter's 2 speed gearbox in front of the NP-435.
Lone Ranger
Lee wrote:Truck_resized.jpgOwned her 17 years.
That thing is sweet! Is it sitting on 35s? I've been throwing around the idea of bigger tires.
What's the two speed gearbox? A spliter?
Kyle
Lee
Post by Lee »
Thanks!!!!
Yes they are 35" s....If I turn to far to the right they do scrub alittle.
The AA gear box is like a Splitter. The 2 speeds are 1:1 (Direct) and 27% overdrive. So,... now I have 8 forward gears and 2 reverse gears. I call them "Half" gears. The advantage is that I tow a heavy trail trailer over a steep mountain pass here in WA state. I can't maintain speed in 4th gear and there is such a wide gear ratio spread between 3-4th that downshifting to 3rd has the RPM's wa'aaay up there. Now I downshift to 3 1/2 gear ;-)
Also, when running empty on the highway I use 4 1/2 for better cruising.
You have to move the NP-435 back 7 1/2 inches, shorten the intermediate shaft, relocate the 435 cross member, relocate the location of the 435 and transfer case shifters, etc... like I said it's a big project.
Manny
Post by Manny »
Lee wrote:Yes they are 35" s....
That thing is awesome. How much lift is underneath it for those 35's. Truck looks great. :thup:
Lee
Post by Lee »
Additional 3" body lift.
Manny
Post by Manny »
Thanks always trying to figure out how they are built. Means I may stick with 33's... decisions decisions
