glove box liners
dotcentral
glove box liners
Post by dotcentral »
I pulled the glove box liner out of my 67 parts truck and discovered they are molded, one piece affairs, no fold lines, no sharp corners. It also has a lip to cover the gap between the liner and the hole for the glove box. Seems like I'd heard they were different, but apparently they are interchangeable.
It seems a little smaller in size, but fit in the 70 easily and with no fighting. The one in my 70 is like the repro's sold by all the venders, boxy and with sharp edges from fold lines and seams. It is a wrestling match to get in and out, and everytime I take it out it gets a little more damaged.
Former owner of 70 LB SportCustom and a 71 SB SportCustom. Looking for a replacement bump!
Heavenlyfire
re: glove box liners
Post by Heavenlyfire »
Glove box liner?? :hmm: You mean there is suppose to be something in that hole :lol: .
Yes they were molded. It's too bad one of us can't figure out how to make a mold and maybe repro a few.
a person could make form to what you would need and tear up several old glove boxes soak them till they fell apart back into the original mush that they were made from strain the mess old through a fine screen this may have to be done several times to check if its ready and then pour into the form and wait.. its the same principle as recycling paper. i seen that done on tv one of those pbs programs. a person could use a blender to chop the pieces even smaller for less soaking time.
oldhalftons
Post by oldhalftons »
thats not a bad Idea
I need to make/buy/redneck engineer something for my glovebox. the 35 year old cardboard is starting to fail. :(
I've been kicking the idea of fiberglass around :hmm:
1969 F100 300/4spd power steering, manual brakes
flyboy2610
Post by flyboy2610 »
Mine must have been replaced at some point. It's made from sheet metal.
Heavenlyfire
I was thinking fiberglass or even a good quality plastic that wouldn't melt.
customcrewcab
Post by customcrewcab »
sheetmetal ones i could do. 48" finger brake does the trick. :D
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
Heavenlyfire
Hey Scott, you should put one together and see how it comes out. I need one for my truck.
oldhalftons
If someone were good with sheetmetal,(and I'm not) I think it would be possible to take apart one of the folded cardboard ones and use is as a sheetmetal templete.
customcrewcab
i been planing on making one but mine is going long gone with eveything else under the dash on that side. was planing on putting a after market ac unit in but not sure how is going to fit and where is going. :roll:
flyboy2610
An aftermarket AC unit shouldn't cause problems with the glove box liner.
460 crew
Post by 460 crew »
My Old Air Products Hurricane A/C heater unit takes up less room than the original heater but does cut into the glove box room and only the shallower liner will fit.
dotcentral
I like the fiberglass idea. I think a mold could be carved out of something and then lay the fiberglass over the mold.
When did the switch to the folded cardboard liner happen? I have to think the folded liner in my 70's was original, I can't picture the people I bought the truck from replacing a damaged glove box liner.
GT-Racer
Post by GT-Racer »
I help a Dirt track team from time to time building aluminum bodys. I was also thinking of taking my folded cardboard box apart and building one with the sheet metal brake. But I havent had time to get around to it either. Shouldnt be hard at all though.
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
bumpside-smitty
Post by bumpside-smitty »
I bought a new one when I first got my truck and never put it in. Since then I have purchased two parts trucks with mint glove boxes. If anyone is intersested in either a aftermarket or used one let me know.
Smitty
72 Ford F-100 4x4 SWB
62 Ford Fairlane Sports Coupe
71 f100 hub capper
http://www.fordification.com/galleries/ ... p?pos=-967
