how to fill a jack with oil?
I have a cherry picker that the oil has leaked out of. What kind of oil and how do you refill it? I don,t know if you extend the jack or leave it compressed? Thanks for any help.Brian.
68 f100 427 r code 4spd toploader
69 f350 390 4spd hauler bed
72 Ford Bronco 302 3spd
95 Ford Lightning
38 John Deere G
Assorted old Honda ATC,s
95 Ford Lightning
38 John Deere G
Re: how to fill a jack with oil?
Leave it compressed and use hydraulic jack oil or auto trans fluid.
there should be a plug on the side , about a 1/3 of the way up.
Is the plug possibly rubber and pulls out?
95 Ford Lightning
38 John Deere G
95 Ford Lightning
38 John Deere G
- flyboy2610
That's the one. Fill it until you can feel the oil even with the hole.
careful not to tear that rubber plug. its heck trying to find another one.
Hey guys thanks for all the help. Just wasnt sure what I was looking for.Thanks,Brian.
95 Ford Lightning
38 John Deere G
95 Ford Lightning
38 John Deere G
I wouldn't recommend trans fluid,but only because using some Dexron i had laying around to fill (an already leaky) rental unit i was using years ago caused a critical meltdown before the weekend was over....cep62 wrote:Leave it compressed and use hydraulic jack oil or auto trans fluid.
probably be safe if you stuck to Type F
- still got my first first car 20+yrs later : 69 f100 sorta kinda pretending its a Mercury M100 w/a 70 f350 sport custom cab (factory buckets) 67 grille with 69 ranger cooneyes 68 merc box and hood,some supercool fiberglass fenders i scored way back when, 76 f150 disc brake frontend..currently running a 90 5.0HO 4bbl/c4 auto & 3.50 posi...originally a 360/c6 f100 Ranger with dealer added towpack (incl. kelsey hays trailer brake),boxside toolbox,behind the seat stowage & belly tank...only original parts left on 'er are the frame,rear end,rear springs,and rear bumper...
Don't skimp here, go to any parts store & get a qt of jack oel...DonnieWhateverman wrote:I wouldn't recommend trans fluid,but only because using some Dexron i had laying around to fill (an already leaky) rental unit i was using years ago caused a critical meltdown before the weekend was over....cep62 wrote:Leave it compressed and use hydraulic jack oil or auto trans fluid.
