68 F-250 Camper Special and 68 F-100 Ranger
Private parties only. No eBay/Craigslist listings.
67 428 F250
Post by 67 428 F250 »
Selling/parting out 68 F-250 Camper Special and 68 F-100 Ranger.
Will
67 F-250 CUSTOM, 428, 4 SPEED, DISC BRAKES, P/S, EATON ELOCKER, 3.54 GEARS
68 F-250 CAMPER SPECIAL 360, C-6
davbell22602
Re: 68 F-250 Camper Special and 68 F-100 Ranger
Post by davbell22602 »
Automatic transmission? power steering? If so I need a automatic power steering column for 2wd F100.
67 428 F250
Yes, the 68 Ranger has p/s with Bendix gear box. I am in the middle of putting the p/s gear box and pump in my 67 F-250. From research my floor shift steering column will work fine, so I will not need the automatic column in it.
Do you have the gear box already? It has to be the Bendix, the Saginaw is longer so the column and shaft would be to long.
What rig are you working on?
Will
davbell22602
67 428 F250 wrote:Yes, the 68 Ranger has p/s with Bendix gear box. I am in the middle of putting the p/s gear box and pump in my 67 F-250. From research my floor shift steering column will work fine, so I will not need the automatic column in it.
Will
67F100 2wd base model. Cant afford a bendix cause i dont have core. Its like $750 with no core from what I was quoted from a ebay seller. I need the PS engine mount perches too.
67 428 F250
Your options for 67 is, 65-68 donor truck done, or 70 Saginaw gear with all steering linkage to wheels because pitman arms are different, (left side engine perch only), 70-72 P/S column w/auto lever with fire wall bracket to change the angle for the Saginaw. We are doing the same thing. I have a 72 Saginaw gear and pump to match, but try to find just the purch or the column.
Will
67 428 F250
Plus I am trying to keep mine looking year appropriate.
Will
davbell22602
67 428 F250 wrote:Your options for 67 is, 65-68 donor truck done, or 70 Saginaw gear with all steering linkage to wheels because pitman arms are different, (left side engine perch only), 70-72 P/S column w/auto lever with fire wall bracket to change the angle for the Saginaw. We are doing the same thing. I have a 72 Saginaw gear and pump to match, but try to find just the purch or the column.
Will
Didnt know all that. So are all the aftermarket gearboxes that arent bendix are all saginaw?
67 428 F250
I have not found any after market gear box, the remans are Saginaw, but I am told you can get the bendix rebuilt
davbell22602
67 428 F250 wrote:I have not found any after market gear box, the remans are Saginaw, but I am told you can get the bendix rebuilt
Who sells the bendix?
67 428 F250
Used only, wrecking yards
davbell22602
67 428 F250 wrote:Used only, wrecking yards
I was thinking new. I dont have any reckoning yards near me with these trucks.
Ford Custom Project
Post by Ford Custom Project »
Do you have a good Hood? I am looking for a Hood for my 67 F100.
67 428 F250
Yep have three hoods, what color do you need?
69rangerf100
Post by 69rangerf100 »
by chance do you have a set of front cab mount bushing brackets that are in good shape these are the brackets that hold the bushings together?
David
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
67 428 F250
Hey David, I will take a look. My daily driver is dad's 67 F-250 4x2, 428 4spd.
Will
