some lowering questions
- greasemonkey060
considering the ford is down for ahwile, im starting to get hungry to drop it the RIGHT way...
In back: Maybe c-section, new leaf springs, and flip the front leaf spring mount. OR leaf spring flip kit, and blocks?
Up front: any ideas??
-i torched the coils up front for a temp drop job, but it still isn't as low as id like. anyone got a inexpesive way??
OH, and has any one had any experience shortening the driveshaft, specifically two piece driveshafts??
-brandon
-brandon
'64 F100 SWB 8" notch, & triangulated four link w/ 2600 Firestone bags out back.
'67 F100 SWB STOCK.
'67 F100 SWB STOCK.
re: some lowering questions
There's some good basic info at the following link:
'67-'72 Ford Pickup Suspension Lowering Basics
- marz68
It can be done but I beams are a pain to work with.
You can't just change or heat the spring to lower or it cause it changes your camber.These old truck that I know of don't have any adjustment for camber like a truck with uper & lower control arms do or 90's Fords with I beams.
The way I would do this is to Z the frame, the only thing you would have to do is modify the steering
shaft from the colum and move the brake line up a few inches.
Another way is to buy some lowerd I beams from DJM and if it's not low enough just bag it or Z the frame to get the drop you want.
You can also go with the mustang 2 front like I did.
Hope this helps. Check out my truck I have a few pics of the suspension.
- ~X~
Greasemonkey.
I changed my leaf spring mounts to under the axle. Lowered it a bunch. The frame now needs a C notch which I will be doing soon. I bought Moroso spring perches from my local speed shop. When i replace my bed I will add the notch and box the frame with a new upper shock mount. Good luck on your I beams.
Marz do you have any pictures of doin a Z on the frame?Or what part of the frame you Z?
- marz68
- rjewkes
question here but what it boxing the frame?
"It is better to keep your mouth shut and appear stupid than to open it and remove all doubt." - Mark Twain
'70 f250 4x4 Crew cab 460/C6 '72 F100 390/C6 9.8 MPG AVG. '89 Mercury Cougar LS Dual Exh. V6 . 18.9 MPG AVG. In Town.
I don't want to give em a heart-attack. That is what would happen if I answered the door in the buff. Heck it almost scares me to death when I step out of the shower and look in the mirror.~Mancar1~
fuelly.com
fuelly.com
Ok that would be great marz.Thanks
- marz68
- marz68
Ok I've got a few questions as well.. i feel bad starting a new topic on this sort of subject, so im using this post. i feel like everyone knows whats up except me.
I'm for sure going to get drop beams in the front. Probably the 4 inch. Maybe the 2. now what springs and shocks do i need? then for the rear to sit level what should i do? will drop shakles do the job? or do i need a c notch?
also for anyone with questions about this i've been saving this post i've read it quite a few times... very helpful on this topic..
http://www.fordification.com/forum/viewtopic.php?t=106
Thanks so much guys.
kyle
kyle
kyle
1971 F100 2wd swb 429 C6
It doesn't look like a very precision way of doing things. Did the trucks drive ok after being z'd ? It would seem like a chassis jig or something should be used..........
1969 F100 Ranger LWB Big Block, factory bucket seats and behind seat storage (arrived 3/21/12) (and it was free!)
1986 Thunderbird Turbo Coupe 247K and still going strong! (sold with 251,758 miles on it!)
1986 Comp Prep SVO Mustang (1 of 83) "the original Fox body "R" model!!"
1972 Ford F-100 LWB SOLD 5/2/6
1995 F150 XLT Supercab (wanna trade for a Bump?)
