Edit: Done! Who would want a D24 t-case support strut?
CrypticRacer13
Re: Who would want a D24 t-case support strut?
Post by CrypticRacer13 »
Mine must be the painted one :thup: your shouldnt have :lol:
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
1971ford
Post by 1971ford »
Got a big pile of transfercase struts on the tool bench! Almost ready to be claimed and shipped :)
-Ryan
1971ford
Post by 1971ford »
Struts are done. Should be able to grab the hardware for them tomorrow.
PM me with your information (Name, Address) to claim yours, I'll give you my paypal email, and once I receive $75 I'll get the strut "kit" on its way!
I was asked to leave one unpainted
I took each strut assembly and bolted it in my highboy to be sure they are all ready to rock. Here is mine bolted in for good.
-Ryan
koch68
Re: Edit: Done! Who would want a D24 t-case support strut?
Post by koch68 »
Does it have a rubber piece on the transfercase side? And does it make a noticeable change while taking off or pulling?
Taylor-
1968 F250 Highboy np435 dana 24 4.10's
1971ford
Post by 1971ford »
Koch68, Check out the pictures on the first page. they show the rubber piece. It's a thick, 4"x4" piece of rubber drilled and sandwiched between the two plates. This is just to avoid solid mounting the t-case, defeating the purpose of the rubber mounts that the t-case hangs on. As for a noticeable change... that depends on a lot of things. A lot of guys have complained on here and elsewhere about the transfercase lugging while mainly pulling. It's not going to move with a strut holding it in place though, that's for sure. Think of it like traction bars on a leaf spring truck. Some people notice wicked amounts of axle wrap, other people never notice it. Also depends on the exact setup. But with traction bars theres nothing to worry about and you know things that aren't supposed to be moving, aren't.
-Ryan
1971ford
Post by 1971ford »
2 left!
-Ryan
basketcase0302
Post by basketcase0302 »
Nice work Ryan. :thup:
luvbumponpp
Post by luvbumponpp »
any more available?
1971ford
Post by 1971ford »
I do have two left. Sent you a PM :thup:
-Ryan
Manny
Post by Manny »
Looks very nice Ryan does the front plate create the seal with a gasket?? How does the rubber hold up under the torque for the cap??? Or does it even use the same bolts??? I know full of :?
1971ford
Post by 1971ford »
Negative... The original bearing cap goes back on just like how it was (with a new gasket or gasket maker), then this assembly goes over that.
The rubber should have no problem holding up to the torque, it's a very firm rubber and is sandwiched pretty good in there. If anything it may be too solid allowing for some vibration, but the rubber mounts that the t-case mounts to are very solid from the factory as well.
-Ryan
Manny
Post by Manny »
Ten four... Just again trying to get and idea how much wiggle this thing has got to give. It's a fine line between making it not flex and eliminating vibration mounting. Seems like you got it right on.
Manny
Post by Manny »
Ryan did you get my PM???????
1971ford
Post by 1971ford »
^ Just now seeing this Manny. Did i see this before and respond? I can't remember now! Sorry if i missed a PM!
I have 3 of these up for grabs now.
http://fordification.com/forum/posting. ... 20ae062fb0
-Ryan
ODES
Post by ODES »
Hi do you still have any Left I would love to have one thanks
