My F-600 Cluster Pics
Heres a pic of my chrome F-600 cluster I will be using in my '69 Ranger. I plan on keeping the Vacuum gauge and cutting the hole out of the right side for a Tach. The small holes on the left side need to be modified so I can install a '72 style flasher switch and a 61-66 style Flasher Warning Light above it. I'm hoping it will work.
BTW, has anyone used the vacuum gauge in the F100's?
'69 Calif Ranger in PA, 2001 GMC Sierra SL 4x4
Liar, Lawyer, Mirror show me, Whats the difference?
- 460 crew
re: My F-600 Cluster Pics
That looks really slick good job!!
Looks good! I'll be using the factory vacuum gauge in mine, plus I have the matching factory tachometer that I'm going to try using. Of course, since it's a mechanical-drive tach I'll have to get an aftermarket tach-drive distributor to drive it.
- jor
That a beautiful set. I look forward to seeing it installed.
jor
jor
Dang I love the looks of those! Are those extremely hard to find out of f-600s? I am looking at these http://cgi.ebay.com/ebaymotors/67-68-69 ... 6793QQrdZ1
or other options. I don't care for the stock look myself. Those you have are really nice!
They are not really that hard to find. They are hard to find in that condition. The chrome is all original, the only thing that is not is the black paint that you DO NOT see, it was stripped off by the guy I bought it from. I think it gives it an even more aftermarket look while maintaining a perfect stock fit. I have two other panels, one painted black with only the standard gauges open and one I found locally with the auxiliary gauges for vacuum and tach cut open but it is rusty. Not sure if I am selling them yet, I have a lot of project left to go--actually all of the project is yet to go. Well, anyway CY'all later
On the F600 panels, many of them have a speedo that tops out at 80 mph, which depending on how you drive is a little low.
Former owner of 70 LB SportCustom and a 71 SB SportCustom. Looking for a replacement bump!
- cobraF100
f100ranger1969,
Who did you Buy that from......
Chris
Never Forget Our Soldiers
A seller from eBay in Kansas I think
