Radius Arm Drop/Extension Project
spartman
Post by spartman »
Keep up the good work boots
Jake11
Post by Jake11 »
Good job, Boot's. I wanna do something like that
to my 71. Your showing us the way. I'm glad your
here.
boots
re: Radius Arm Drop/Extension Project
Post by boots »
I have been sick for the past few days so have not got any time in the garage! its just so cold out side also, this week im getting a woodstove put in so I can really get things going. Ill update soon.
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
boots
Post by boots »
Ok, I got out into the shop today and did something besides clean! I put the left side together and now all I have to do to finish the side off is bolt up the bracket, and put the shock back in. I can see where my caster will be by putting a jack under the i-beam, and it looks just about perfect... in the pictures, the coil is compressed just like it would be sitting with tires on.
pictures:
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
Jake11
Post by Jake11 »
Couple questions.
Do you have the part # for the springs you used, and are you happy
with them so far? Same question about your hedders. Looking real good!
Thank's Keith P.
I like the red radius arms. :)
boots
Post by boots »
For my headers I got dynomax standard series from jegs, part # is 289-85041. My dads buddy owns a jeep shop and we went over their one day to see some parts, I asked him about coils and he had some but they didnt have a box, and were brand new. He said they were rancho 4" lift coils for a f100-f150 2wd and 4wd, but was not sure. So he said take them home and see if they fit. They did :D. From what I have read, all coils from Broncos, f150's and f100 will fit on your truck w/o a problem. You can see on jackit.com they sell skyjacker lift coils and they say "F100/F150/Bronco".
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
Jake11
Post by Jake11 »
Thank's Boots. I got a 250, but the front should be about the same
weight as a 100. It's got 32" tires on it and they just rub a bit going
thru dips or over curbs and stuff. :lol:
460 crew
Post by 460 crew »
Hey boots I came across this lift with Camburg and was wondering if you had seen it? http://www.camburg.com/fords1P.html The equal lenth system is sweet!!
boots
Re: re: Radius Arm Drop/Extension Project
Post by boots »
460 crew wrote:Hey boots I came across this lift with Camburg and was wondering if you had seen it? http://www.camburg.com/fords1P.html The equal lenth system is sweet!!
dang, I never saw that before, that is some sweet stuff!!! just alot of money to get your 2wd up in the air though!
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
heep70
Post by heep70 »
You done yet. I wanna see :cry: :cry: :cry: :cry: :cry:
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
1970F250
Post by 1970F250 »
:yt: lol
Steve
boots
Post by boots »
heep70 wrote:You done yet. I wanna see :cry: :cry: :cry: :cry: :cry:
ive been working on my front bumper buildup right now, the only reason Im not working on this is because I cant drill the 1/2" holes in my brackets. Im getting a drill press next week so I can finnaly finish this(as well as welding gas :)). I tried drilling through my brackets with a hand cord drill but it was just hell. Also in 8 days im going to england until january 3rd so it will be about about january 8th when I finish this. I will update as soon as I get some stuff done!
here is a few shots of my front frame that I boxed. Im doing a front 6 5/8" tube bumper, 1/4" thick sidewall, and I boxed the front of frame so I can get a cleaner look, and so I can flatten the top down.
http://img.photobucket.com/albums/v629/ ... 010053.jpg
http://img.photobucket.com/albums/v629/ ... 010054.jpg
http://img.photobucket.com/albums/v629/ ... 010055.jpg
http://img.photobucket.com/albums/v629/ ... 010051.jpg
and a shot of the bottom left side before it was finished..
http://img.photobucket.com/albums/v629/ ... 010052.jpg
See!!! Im not being a lazy a$$, im actually doing stuff! :twisted:
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
heep70
Post by heep70 »
Thanks, I was going through withdrawls :wink:
You doing a box tube bumper or round?
Greg
boots
Post by boots »
heep70 wrote:Thanks, I was going through withdrawls :wink:
round :)
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
460 crew
Post by 460 crew »
Any pics of the design your lookin at?
