coil springs
coil springs
Which springs do I cut to lower the back side there are two sets?
re: coil springs
Right, your truck should have leaf springs in the back. If you've got coils then somebody has done some major work to the backend of your truck.
...unless your talking about coil-over shocks, which are an entirely different entity. Those are simply to add to the load capacity and won't affect how high the rear sets.
re: coil springs
It ha two sets of springs and leaf springs
re: coil springs
Excuse my past reply, it has leaf springs of course but it has two sets of springs. I take the coil overs are shocks with springs around them and there is also springs like the ones in the front but shorter resting on top of the rear.
re: coil springs
Those are aftermarket overload springs too. Apparently the previous owner was doing some heavy hauling and wanted the extra payload so he added those springs. You can just remove them and their brackets completely....they aren't needed. The only springs needed in the back are the leaf spring assemblies.
re: coil springs
I wanted to know if i remove them will it lower it. I have been wanting to level the back to the front height and heard you could cut springs if you just want to lower a little.
- 72hiboy4x4
- Location: As far away as I can be from Wa state, without crossing the Mississippi
IMO since shocks (and/or overload shocks) do not control the ride height, cutting the coils on the shocks will not do anything to lower the truck.
if your leaf springs are mounted under the axle, you can get lowering blocks from a performance/parts store and install it to get the look you are after.
this kit will include lowering blocks, and new u-joints.
summit racing has them for other type trucks..........
http://store.summitracing.com/default.a ... p&x=32&y=6
as for cutting the coils, IMO that only works on the front of our trucks. if your going to do something, do it the right way. cold cutting (with a chop saw or similar) will keep the temper of the springs intact. cutting (or just heating) with a cutting torch will eventually leave you with a lot lower drop than you expected.
hope this helps! and Merry Christmas to all!
The HD coilover shocks that people use for overloads do affect the ride height, they provide about 300lbs per inch of additional resistance, and usually pick up the rear about 1.5" over stock.
Post a picture of the truck as it sits now, or the measurement from the ground to the body line above the wheelwell., and we can figure out how much higher it is than it should be.
- ~X~
re: coil springs
Putting the axle over the spring will lower it alot more than what you are looking for IMO. I dont know of an F100 that ever came with the spring UNDER axle, at least in the years we discuss here.
Do the math: axle tube-3", spring pad approx 3/4", spring pack approx 2 1/2". The bottom of the spring pack rests on the top of the spring pad and its on top of the axle tube. Now, picture the top of the spring pack contacting a new spring pad UNDER the axle.
I mounted my springs under and it dropped it alot, probably 7-8", just what I wanted. But if you are only wanting to match the ride height to the front you might want to start by getting creative with your spring hangers and leave the spring pads where they are. Keep in mind that the front spring mounts locate the axle for proper alignment so messing with the back would be safer. Or, you are in for alot of work if you place a new pad under the axle to lower it and the RAISE the rear some to match the front!
I know, my shock angle is wrong now and the frame needs a C-notch and has to be boxed. Taking the bed off makes this job alot easier so Im holding off til I get my new bed ready.
- 1970F250
re: coil springs
are you looking to lower it or just level it out? because it would be less work to just put spring spacers in the front.
Steve
re: coil springs
Ok just for the record our trucks only have leaf spring packs in the back right ? Mine has those aftermarket springs that rest on top of the rear and push up. It also has coil-over style which brings me to the point. The back is raised a little more then the front, which bothers because of the gap between wheels and bed. I don't want to slam it or anything but simply level it with the front. Shouldn't the removal of the two extra sets of springs bring it down. It's not a f-250 or camper special, one with heavy duty leafs which commonly came higher in the back then f-100?????
