1967 f250 mod - 460 with zf5 swap
Questions about 4WDs and related topics
Aesop
Post by Aesop »
I have my bed and rear frame nearly done except for bodywork and paint.
http://www.fordification.com/forum/view ... =7&t=73514
I bought a 86 f250 4x4 that I am going to rob the zf5 and transfer case for this swap. I am nearly done with my 460 externally balanced rebuild. The clutch master looks easy enough to fab in, and I will butcher my towers like this.....
http://7879blueovalbronco.com/forums/sh ... .php?t=834
I want to know if there are any cab issues, or if one of you guys have done this before. The search function has never worked on this site so don't scold me.
67 F250 4x4
Aesop
Re: 1967 f250 mod - 460 with zf5 swap
Post by Aesop »
I guess I will set the engine, tranny, and transfer case with headers installed to ensure clearance, then shave the original towers. I think if I set the intake carb base at zero or maybe +1 or 2 in order to account for weight gain I should be all right. The front end is removed right now. My only real concern is cab interference and fan to radiator clearance.
67 F250 4x4
KRob
Post by KRob »
This is apples to oranges so its probably not even worth bringing up.
When i put my 4BT / zf5 / 205 combo into mine i had no issue with the cab. However i alligned the engine/transmission combo and then built the motor mounts. Where as you are probably going to use the original motor mounts.
71 F250 4x4, 4BT Cummins Mostly Done...Project Thread http://www.fordification.com/forum/view ... 22&t=65450
(4BT, big block ZF5, 78 NP205, 78 Dana 44 Front axle, 4.10, 265/75/16, power steering, power brakes)
01 Dodge 2500 4x4 Cummins...turned up a little.
Aesop
Post by Aesop »
I know I will need to lower the towers and using the late 80's motor mounts is an excellent and cheap mod, and you are right, since I am not injected the carb base needs to be at zero. That really limits my drivetrain centerline and my vertical is going to be limited by the headers. I know I will make this work. My 460 will only be around 425+HP so I shouldn't need any reinforcing up front. If you can cram a Cummings in there with no cab issues then I shouldn't have any problems either. Thanks for the heads up, that makes me feel better.
67 F250 4x4
