rear susp. Removal.
- rjewkes
rear susp. Removal.
what is the best and safest way to remove the axle springs and all?
"It is better to keep your mouth shut and appear stupid than to open it and remove all doubt." - Mark Twain
'70 f250 4x4 Crew cab 460/C6 '72 F100 390/C6 9.8 MPG AVG. '89 Mercury Cougar LS Dual Exh. V6 . 18.9 MPG AVG. In Town.
I don't want to give em a heart-attack. That is what would happen if I answered the door in the buff. Heck it almost scares me to death when I step out of the shower and look in the mirror.~Mancar1~
fuelly.com
fuelly.com
jack up the truck put the frame on blocks. remove the drive shaft. put a jack under one side of the axle until the spring starts to go up a little then remove the bolts . rest that side on a block or something and then do the other side. once evrything is out and loose knock it off the blocks and drag it out.
- rjewkes
thanks fordman. t5rying to get this rear end out so if the truck out your way is for sale i can get it rollable.
fuelly.com
fuelly.com
