lowering leaf springs
F-100Ranger
Post by F-100Ranger »
Has anyone used, or know anyone who has used, the rear leaf drop springs offered by some of the parts catalogs? I want to drop the rear by two inches.
I already prepped and painted my frame and don't want to take off and replace the front leaf spring mounts with lowering ones unless I really have to.
Thanks in advance for any info you all can supply.
dragtruck
re: lowering leaf springs
Post by dragtruck »
You will be money ahead and have less hassles with the drop hangers,if you want lowering leafs take yours to a spring shop and have them de arched or stiffer springs with less leafs,those so called lowering springs are a one size fit all so you can guess how that will work.
F-100Ranger
Thanks dragtruck. Why can't these project trucks finish themselves?
marz68
Post by marz68 »
You can also get a flip kit and you can keep your stock leaf springs.
