major toe-in problem...maybe...?
- Billybobjunky
Put a '77 front end on the ole '67 including the '77 coil springs, i believe the 77 springs were for the V8 application or something because they are taller then the original ones I took off. I figured this would work bc the original springs were matched to the trucks inline 240. Well it now has a 351m, so should these newer springs be ok, bc right now, truck empty of an engine, I get major curve-under. Think this will level out with the additional weight of the motor? See for yourself...Right SideLeft Side
1967 SWB 2wd F100
-'77 V8 [[[410]]]
-'74 C6
-Re-wired main harness
-Disc Brakes/Power Steering
-'77 V8 [[[410]]]
-'74 C6
- Heavenlyfire
- heep70
re: major toe-in problem...maybe...?
I agree, Its fine
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
Mine's the same way. By the time you get the engine, tranmission, and all the bodywork back on it, it'll settle down. Don't worry.
- rjewkes
Mine did half that with the front sheet metal and radiator & support out of it.
fuelly.com
fuelly.com
