what do ya think
what do ya think
i just put an automatic in my truck witch origionaly had a 4 speed i been deciding on what to do with the pedal i coonsidered cutting it out also leaving it there for the heck of it heck i even thought of making some aperadious to make cutouts on my exaust with the cluch pedal what youal think
re: what do ya think
Just hook a large heavy spring onto it, and use it for exercise equipment while waiting at the stoplight.
Or you could put a spotweld or two in a strategic place to keep it from pivoting, and then just use it as a footrest.
Nah, I'd either just cut the pedal and arm off the pivot pin or replace it with a regular automatic pin, to get rid of the pedal altogether.
- binder56jd
If it ain't wore out i wouldn't butcher it- you or someone else might want or need it someday. jd
now serving #235
now serving #235
- 19674x4
hook it to a spring on your exaust so when you come to a stop light, you push the pedal and it bypasses your muffler. so when you take off it's really loud
My Photo Album
2012 Cummins-the luxury Tow Pig
1967 F-250 highboy 352, np435(((((((sold))))))))) My first true love
1968 F100 SWB. 360, np-435, flatbed, currently acting as a hornest nest and bee hive.
1971 F-100 4x4 Step-side. 360, np-435, 70k origional miles- needs allot of love.
- ToughOldFord
Generally I try not to think, that process had led to many a person getting into trouble.
You could put a spring on it and leave it there just to confuse the heck out of people. Or tell riders that it activates a self-destruct mechanism.
Me, I'd take it off. Actually, I'd never have converted to automatic in the first place, I prefer standards, but again that's just me.
- binder56jd
or hide the auto shifter & leave it in place as an anti-theft device jd
now serving #235
now serving #235
Sure is strange....I have an Automatic and would love a 4 spd.....wonder how many of these conversions take place......might be easier if we just swapped trucks instead of trannys..................
- 1970F250
Re: re: what do ya think
ToughOldFord wrote:Generally I try not to think, that process had led to many a person getting into trouble.
Steve
- Comet
I'm putting a C6 in my truck, it's a hiboy and was never offered from the factory. I was planning on replacing the pedal assy. with an auto pedal assy from a 2wd, but then I got a donor cab that is already set up that way. I needed a new cab anyway. I would remove and replace and keep the old stuff. It's easy and that way someone else can swap back if they are so inclined.
I also prefer manual trannys. All my vehicles are stick, even my commuter. Part of me wants the auto in the truck for the novelty, part because all my other junk is stick, but mostly because I'm planning on using it as a tow vehicle and don't want to go through clutches. The C6 is perhaps one of the best trannys ever made for towing. If the C6 is good enough for Big Foot, it's good enough for me.
That's MR. Jackass to you fellah!
- FordPickup460
I just yanked the C6 out of my Highboy and replaced it with a NP435 and I love it. It makes me want to put a manual in all my trucks. I have better acceleration, stopping, and mileage. The ONLY thing I do not like about it is there is no "Park" option.
~~~Big Trey~~~
76 F250 4x4 390/NP435/NP205/D44HD/D70U
77 F150 4x4 460/C6/NP205/D44HP/9"
57 F100 4x2 351w/C4/9" 3.70
I will have a 67-72 someday, I promise.
- 72hiboy4x4
- Location: As far away as I can be from Wa state, without crossing the Mississippi
sure there is. just put it in first gear when you 'Park'. it AIN'T going NOWHERE!FordPickup460 wrote: The ONLY thing I do not like about it is there is no "Park" option.
Done this with my Hiboy for 10 years now, and its never rolled an inch!
- 1968flareside
An ejection seat switch!!!
1968 F-100 Flareside
1999 F-150 XLT 4X4
http://www.fordification.com/galleries/ ... ?cat=10023
and DON'T FORGET!!
1999 F-150 XLT 4X4
and DON'T FORGET!!
