transmission
1970F250SC
transmission
Post by 1970F250SC »
hey, guys whats up again,, yesterday, i became aware of the chance to buy a t-18 or a t-19 transmission for my truck {2wd f250}< its automatic, and i want it to be manual, but i know these tranny's have a PTO output, ,, what would that be for? , and im wondering if it would work, besides the bellhousing,and tailshaft? , basically, im just wondering what all i would need to do for it to work thanks __ jeff
"NOTICE, Insanity has replaced all reason in the design and construction of this vehicle"
1970 F250 Sport Custom, 360FE
1964 Thunderbird, 390FE, Offy intake, holley 4bbl,cam, open exhaust
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
well the PTO on my truck runs (ok ran) the front mounted winch on my truck.
but it is installed in the transfer case, not the tranny. which means I had 4 speeds power in, and 1 speed power out, (or was it the other way around?? I can't remember??)
and sure it will work. you need the bellhousing, clutch set-up. pivots on the frame and the bellhousing/engine block, clutch linkage, cluch pedal assy, floor shifter cover, and the proper driveshaft for your truck. then you will want to change your steering column to match. (did I miss anything? probably!)
I've done this swap. with a donor truck or a bunch of scavenging, its pretty easy.
Good Luck!
1970F250SC
re: transmission
thanks mike, im just seeing what all i will need to get together, for my myself to do it, i didnt think it would be hard to do, just a little time consuming, thats all,,, _jeff
mrung0wa
re: transmission
Post by mrung0wa »
FYI: PTO stands for "Power Take Off" with a PTO set up you can operate all sorts of implements!
Lawrence 8)
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
hey how about a three point hitch to go with it. :lol:
mrung0wa
re: transmission
Post by mrung0wa »
Is that like a 3 point turnabout?
Lawrence 8)
