shaking
jhannahokla
shaking
Post by jhannahokla »
i got 1970 f100 and it has a 3spd manual trany and every time i let the clutch out the whole back half of the truck shakes but it onley does it when i give it gas. would that be the clutch or the rear wheel bearings.
mrung0wa
re: shaking
Post by mrung0wa »
Sounds like the clutch/tranny to me!
What kind of noise do you hear when this happens?
Lawrence 8)
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
Fordfool
re: shaking
Post by Fordfool »
Maybe a carrier bearing. I had that happen before. vibrates like mad.
My Gallery
"Knowing is not enough, we must apply,willing is not enough, we must do" -Goethe
jhannahokla
re: shaking
a real fast shuddering
Jake11
re: shaking
Post by Jake11 »
CK the driveline. U-joints, and make sure the U-bolts on the rear axle
are tight. If you have a jack and stands you can jack up the rear axle
and put stands under it and run it in gear to see whats going on. Or pull
the driveline out and CK the U-joints to see which one is binding.
binder56jd
re: shaking
Post by binder56jd »
my old 72 w/3 speed and 3.25 gears had new clutch and everything on back- it would always shudder at take off-the gears were just to high for the 3 speed- have seen newer fords w/ same problem-jd
now serving #235
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
:yt: I changed an auto to a 4 speed once and it always had a shudder after that. didn't have it before.
I figured it was the higher gears that caused it.
jhannahokla
re: shaking
or could it be the transmishion mounts gone soft
jhannahokla
re: shaking
I am going to put a new clutch,u joints,rear wheel bearings in any way if it dont stop then i guess i got a serious problem
cdeal28078
Post by cdeal28078 »
My 71 f100 always did that when it was still a straight drive, until I went to a diaphram type pressure plate. It could also be caused by the flywheel being glazed over. It is always a good idea to have your flywheel surfaced when installing a new clutch kit.
I went to an automatic and stopped all the shaking. lo
clint
71 F100 SportCustom
460 C6. Disc Brake/Power-steering/automatic Swap. 3.00
1986 Bronco 5.0 AOD
bwc302
re: shaking
Post by bwc302 »
When I have seen this in the past it was clutch, pressure plate and throw out bearing.
Bobby
Leadfoot
re: shaking
Post by Leadfoot »
I have that problem often in my trucks, normally its because I'm hard on the clutch and I rip the disks damper springs apart. First thing stop dumping the clutch at lights :hmm: The 10" clutch don't like this.
then replace the disk I'm so aggressive that now I just use autowecker disks (on the old small diameter clutches)
cause even new ones only last 1mo. :cry:
Only once was it from the drive shaft it self.
WHAT ?
Heavenlyfire
Post by Heavenlyfire »
I'm with bwc302 on this one. Check out the throw out bearing. I had that same issue on a hot rod that I use to have and that was it. If you are going through clutch plates then you may want to go to Napa or some other big name part dealer and have them line you up with a performance disk that is a little thicker and tougher.
Leadfoot
Post by Leadfoot »
Heavenlyfire wrote:I'm with bwc302 on this one. Check out the throw out bearing. I had that same issue on a hot rod that I use to have and that was it. If you are going through clutch plates then you may want to go to Napa or some other big name part dealer and have them line you up with a performance disk that is a little thicker and tougher.
I looked around for months. And I didn't come up with any performance clutch for the old small diameter clutch set , later I got mad and use one for a 460 or something in conjunction with a new used large flywheel & bell housing. It was bigger diameter and I was able to get a performance clutch set.
WHAT ?
