Should I replace or rebuild? Steering gear box
Godspeed128
Post by Godspeed128 »
Is this A typical 1967 F100 steering gearbox? I’m doing a restoration of this old truck Should I replace it rebuuld
d
Busboy
Re: Should I replace or rebuild? Steering gear box
Post by Busboy »
It depends on ones mechanical ability. Parts for it might be a challenge to locate.
1967 F-100 4x4 custom cab.
jzjames
Post by jzjames »
Would just get a rebuilt one and be done with it. :2cents:
Godspeed128
I have a doner truck that may have a power steering setup in it if so I will most likely use it
crazyhorse
Post by crazyhorse »
Mr Godspeed, either way seems good. :thup:
I like your "name'.
:fr: :fr: :fr: :fr:
Mach428
Post by Mach428 »
I have a perfect manual steering gear that I removed from my 25,000 mile 69 to install PS. My Dad bought this truck new and I've owned it for 42 years so this is not some worn out junkyard part. Let me know if you're interested. Has the pitman arm already installed.
