Trans linkage
Re: Trans linkage
Glad it works! I'd just leave it bare. Thanks for posting it!
Redcrew71
Re: Trans linkage
Post by Redcrew71 »
just seen this post. I posted having a problem installing a new C clip to hold the shift linkage to the column shift at the top by the firewall. noticed one one pic here a bolt was used? wondering how the heck to install the c clip does not want to push down onto it and bends easily. thanks.
Ron_Hall
Re: Trans linkage
Post by Ron_Hall »
Redcrew71 wrote:just seen this post. I posted having a problem installing a new C clip to hold the shift linkage to the column shift at the top by the firewall. noticed one one pic here a bolt was used? wondering how the heck to install the c clip does not want to push down onto it and bends easily. thanks.
Redcrew71 Are you using the nylon bushing or the rubber/brass? From what I understand with the nylon you don't need the C clips or E clip but they are a total pain(to me). Your C clip might be too thick to fit in the little groove. Some guys drill the rod ends for cotter pins also.
I made my own linkage using the Heim joints(reason for bolts)
Hope this helps.
Ron
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
Redcrew71
Re: Trans linkage
Post by Redcrew71 »
Hope this helps.
Ron
its stock...the c clip is very thin from Dennis Carpenter. rubber insert i have.
