Bleeding of automatic transmission necessary?
timachone
Post by timachone »
Hi guys,
I want to change the fluid of my tranny including empty out the converter and sealing up a leaking transmission cooling line on the radiator. Do I have to "bleed" the transmission after that, especially when I have disconnected one transmission cooler line for some time to seal it up? Or just let it idle, shift trough all gears and P and N and that's it? Does a C6 bleed itself by operating?
Thank you :thup:
Tim :drive:
1970 Ford F250 360 FE 2V C6
1973 Ford Mustang Mach 1 351C 4V 4-speed
2012 Ford S-Max 2.0 EB AT
2017 Skoda Fabia Monte Carlo MT
Busboy
Re: Bleeding of automatic transmission necessary?
Post by Busboy »
No bleeding necessary, it "self bleeds" by purging any air into the trans pan which is open to atmospheric pressure.
1967 F-100 4x4 custom cab.
timachone
Post by timachone »
Busboy wrote:No bleeding necessary, it "self bleeds" by purging any air into the trans pan which is open to atmospheric pressure.
Perfect - thank you :thup: :thup: :thup:
:fr:
Tim :drive:
mmerlinn
Post by mmerlinn »
As noted above, no bleeding is necessary. The reason, as implied above, is that the fluid system is not a closed system like brake systems. Just like the engine, the transmission, transfer case, & rear end are all open systems.
mmerlinn (http://mmerlinn.com/catalog/makeridx.htm)
"People who are careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Steven Raymond
timachone
Post by timachone »
mmerlinn wrote:As noted above, no bleeding is necessary. The reason, as implied above, is that the fluid system is not a closed system like brake systems. Just like the engine, the transmission, transfer case, & rear end are all open systems.
Thank you for the (technical) addition! Good to know :thup:
:fr:
Tim :drive:
