C6 modulator question
RottenAppleRed
Post by RottenAppleRed »
I need some help in an area where I know little. I have a 351 Cleveland backed with a C6 that was pulled from an ambulance and built for street/strip some years ago. I decided to install an adjustable TCI modulator. Here is where things got strange. I pulled the current modulator with no issues and the push pin cam out with it...normal. I installed the pin in the new unit and it sticks out quite a bit more than it did with the old one. I’ve been trying to find a spec online for pin depth or protrusion and I’m at a loss. The difference I notice is that the current unit has a black stripe and the TCI unit is a purple stripe. Any and all help appreciated.
RottenAppleRed
Re: C6 modulator question
I’m trying to post pics of them, but they seem to be too large to load from my iPhone.
DuckRyder
Post by DuckRyder »
Take a screen shot on your phone that should reduce the pictures...
I have a book I will see if it says anything this evening.
aquartlow
Post by aquartlow »
This thread may help: https://www.460ford.com/forum/47-drivel ... r-pin.html
Hope this helps.
DuckRyder
Post by DuckRyder »
Crud - sorry man I forgot to look... and I can’t find the book immediately...
RottenAppleRed
It finally hit me...to send the pics to myself via email and downsize them that way. Hopefully this works. I’m going to try to find a Ford trans guy in the area that may know.
The 460 thread that was posted is a little helpful, but I just want a definitive answer, so I can move on. I’m also going to take the old one back out and head to a Ford dealer...maybe I can get some pins, who knows. Thanks again.
