460 transmission
wcm413
460 transmission
Post by wcm413 »
Hi , I was reading on a website that a C6 transmission takes 50 to
60 horsepower from your engine . Anyone know if this is about right ?
Also would anyone know what kind of 4 speed manual transmission,
not the granny gear type that would bolt up to a 460 ? Thanks for any
info .
Bill
i think it is the bellhousing that you will need for a 460. i think from what i've read here that all manuals will bolt up genericly to any ford bellhousing. being that its just four bolts that hold the tranny to the bellhousing.
460 crew
re: 460 transmission
Post by 460 crew »
I have a 460 bellhousing but it only accepts a 360 flex plate or something like that, a smaller diameter flexplate and clutch assembly. Contact Heep70 He will have the details and you can let me know if your interested in the bellhousing I have.
wcm413
Post by wcm413 »
I've been reading about some things you can do to
a C6 to reduce friction and increase horsepower . I'm
going to check in to that and see how costly and just how
much it'll help because I know its bound to be pretty
expensive for the change over to a manual transmission
which is what I'd like to do but money is an object . I
appreciate your help tho .
Thanks ,
Bill
Jake11
Post by Jake11 »
Where do these guys come up with this stuff? In 3rd a C6 has the input
shaft locked to the output shaft. 1to1 !!
binder56jd
Post by binder56jd »
overdrive? GearVendors?($2100.00+ bolt on overdrive) for a 20-30% increase in mileage- if you were doing a good bit of hiway driving it would pay for itself inside 20,000 mi-jd
now serving #235
wcm413
Post by wcm413 »
I think they replace somethings in the transmission with needle bearings
and that reduces friction which increases horsepower in the lower gears
plus the torque converter eats up some horse power too . I dont do any highway driving at about 8 to 10 miles to the gallon its strictly a hobby
truck .
Jake11
Post by Jake11 »
OK, here's how it works. If you've been inside a C6 the first thing that
you'll notice is the massive size and weight of the drums and planets.
Say compared to a 400. To accelerate the car, this stuff has to spin up
to speed by the engine. Kinda like having a too heavy flywheel. Funny
thing is. I think there are some records set in S/S with a 428/C6. I could
be mistaken. :wink:
wcm413
Post by wcm413 »
That makes sense . This is the info I found on a built transmission. The main problem I have tho is the stock leaf springs that came on the truck cant handle the engine and it will bend the longest leaf at the front connection . My son found some but they must have been 1 ton because
they sat centered on the rear end housing and mine have about a 24" front and 28" rear off set plus they were a few inches longer . I'm still
trying to find a cure for that . No need in adding more horsepower until I get that taken care of .
Thanks ,
Bill
INTERNAL COMPONENTS AND FEATURES: SIX STEEL CORE FORWARD RED RACING FRICTIONS INCREASE THE CLUTCH PACKS HOLDING POWER AND ELIMINATE INTERNAL CLUTCH SPLINE FAILURE (ONE OF THE C6’S BIGGEST PROBLEMS). SEVEN RED DIRECT RACING FRICTIONS INCREASE HIGH GEAR CLUTCH PACK DURABILITY, OVERSIZED RED LINED INTERMEDIATE BAND AND OVERSIZED BILLET STYLE SERVO ASSEMBLY IMPROVE SECOND GEAR FIRMNESS AND REDUCE BAND OVERHEATING. LOW REVERSE ASSEMBLY FEATURES SEVEN E4OD STYLE HI-ENERGY FRICTIONS, AND NEW E4OD ONE PIECE ROLLER CLUTCH ASSEMBLY ELIMINATING CLUTCH CHATTER AND SLIPAGE IN REVERSE. NEW 300M INPUT SHAFT AND HEAT TREATED FORWARD DRUM ASSEMBLY. ALL METAL THRUST WASHERS ARE REPLACED WITH HI-CAPACITY TORRINGTON BEARINGS, WHICH REDUCE INTERNAL FRICTION AND HORSEPOWER LOSS CONSUMED DURING NORMAL INTERNAL COMPONENT ROTATION. EARLY STYLE OUTPUT RING GEAR AND HUB ELIMINATE SPLINE STRIPPING FAILURES. INCLUDES OUR COMPLETELY RECALIBRATED VALVE BODY AND GOVERNOR ASSEMBLY AND ADJUSTABLE MODULATOR.
all caps is hard to read
wcm413
Post by wcm413 »
Sorry about that , I just copied and pasted it , I didnt even notice .
willowbilly3
Post by willowbilly3 »
I have heard reports of 30+ horsepower parasitic drain. But who knows what gear and what rpm these numbers come from.
I didn't know there was a big block C4 until recently. Apparently there was some few 351M engines that came with a C4. I saw the bell housing for one go on ebay last week.
I am running a toploader 4 speed behind mine.
wcm413
Post by wcm413 »
My choice would be a 4 speed or after market 5 speed but
I have more green in my yard than I do in pocket : ^ ) .
