PaPa's 69 F100 Explorer Coyote 10R80 swap
Venomous duck
Re: PaPa's 69 F100 Explorer Coyote 10R80 swap
Post by Venomous duck »
Here are the old support mounts.
Venomous duck
I purchased the mounts from Dennis Carpenter. I installed them but they are are flat. The original ones have a raised center that fits down in the frame to locate the support. I think these would be fine if you were replacing them one at a time but it was causing problems for me. I decided to see if I could reuse the old bushing and parts or combine the new kit with the old parts.
Venomous duck
Next I had to find a way to trim down the washer to the correct size.
Venomous duck
The bushings that have the raised portion were good enough to reuse. The other bushings were starting to crack. The new bushings are the same thickness and outer diameter. The diameter of the center hole is way to small. If I could find a way to make the hole bigger then these will work.
Venomous duck
Next I zinc plated all the washers then painted the the orange ones. I used the new bolts and washers, zinc plated them as well.
Really nice work.
Venomous duck
Venomous duck
Next I put in the radiator. I had already bought a radiator for the FE engine. The upper hose flange is 1-3/4 and the lower is 2.00. I started thinking I could adapt it down to the 1-1/2 of the Coyote. I am really over budget and need to save money if I can.
Venomous duck
I got a hose adapter from Power By The Hour so I would have more flexibility in fitment.
Venomous duck
I then tried putting the upper on the lower and the lower on the upper.
Venomous duck
I decided that trying to adapt the radiator was going to complicate things. I would rather not have to custom build a replacement hose when the hoses do need to be replaced (although I doubt that will be my problem). I ordered another radiator with 1.500 inlet\outlet. Looks Like another new part going to go up for sale at some point.
Venomous duck
On to the FEAD. I purchased the kit from Turn Key Powertrain.com. It comes with a Sanden SD7 compressor and a PSC P/S pump. What I like about it is a direct bolt on. I can use the Boss alternator kit that the engine came with, and it does not require moving the alternator and running it backwards which requires a new pulley and grinding on the new engine. It also may make mounting fans more problematic due to the tight space created on the passenger side of the engine. What I don't like is with the PS pump mounted where it is I will have to spend more time fiquring out the hoses and cooler set up. I was planning on Hydroboost but that seems unlikely at this point.
Venomous duck
The directions were very good up to a point. There is no mention about the bracket for the reservoir. I thought a page may been left out. I downloaded the instructions from the website. This was no help. I fiqured it out after a few minutes but it was not obvious.
Venomous duck
I have been away for a while due to major repairs and maintenance that need to be done on my home. As soon as it was too cold to work outside I was able to get back on the project. On with the overdue update. My intent was to continue getting the engine to fire up. I tried to install the headers and discovered the flanges were rocker shaped. They fit tight in the center but the outer flanges were about 3/8" from contacting the head. I sent them back to Fat Fender Garage. Of course they took care of it but it took months. Anyway I decided to move on to the rust repairs to the cab.
Venomous duck
It needs repair to most of the normal areas, cab mounts, floor pans, rockers, floor brace, inner and outer cab corners. I am very lucky the rust is relatively minor when compared to many others I have seen. The next thing I did was build a simple jig to locate the cab mounts. I don't know yet if this was a good idea or a waste of time. At some point I will find out.
