72 f250 4x4 old blue
Re: 72 f250 4x4 old blue
Question- here is my rocker and a pillar.
On the left is an angle piece I added to the replacement inner rocker to make the lines look better. Do I need to do continuous spot welds or the few tacks you can see ok? Should I do seam sealer next then primer?You do not have the required permissions to view the files attached to this post.
1972 f250 4x4 390 4speed
- jzjames
Alright
One step forward and two back. I tackled a piece of the cab that I had been avoiding. Here's what I had to work with
to make this
But I decided to pull the engine and get a better look at things and found this
At least to bent pushrods on each side. Looks like I'll be searching for a cheap 390 crank since I'll have everything apart.You do not have the required permissions to view the files attached to this post.
Picked up a "new" engine, came with this gem:
Has a 390 2bbl that runs good. Bought the car for $400, pulled the motor and scrapped it. Just have to swap my oil pan,pickup tube, and motor mounts (glad I read about grabbing the crank bolt with the stud).You do not have the required permissions to view the files attached to this post.
Nice score!
Great find. Looking forward to seeing more updates.
Any updates?
Broke off 5 out of 8 upper manifold bolts on the 390, 2 of them came off with vice grips, 3 drilled and tapped. Have done a lot to the cab but have a long way to go. Here is my new floor at the rear cab mounts
Next step is making inner cab corners.You do not have the required permissions to view the files attached to this post.
Wow! Now that's a lot of good fabrication there. Very nice progress.
Nice work!
Finished my inner cab corners, just need to tack them in place
Thought you would get a kick out of my "sheet metal brake" I sandwich it in my hydraulic press and beat it down. Had to break out the big hammer for the 16ga metal!
- jzjames
Metal shapin’
Brute metal bender!
I'd be embarrassed to say how many hours (beers) I have in this rocker panel. New top and back side and a few inches of the curved part. Aftermarket rockers weren't even close.
Well, I say it looks good.
