Does anyone know where I can possibly find a power steering pulley for my 1972 F100, 360 ci. I have looked online at all the places I thought might have one with no luck. Any advise on where I might be able to locate one would be appreciated.
Thanks in advance.
Dave
Where to find an aftermarket power steering pulley?
Re: Where to find an aftermarket power steering pulley?
You could try to locate an original used pulley on the Fordification parts for sale & parts wanted section: http://fordification.com/forum/viewforum.php?f=11 or try the junk yard search here, that has contacts to junk yards around the country:
http://www.car-part.com National Parts Depot has a billet aluminum power steering pulley for 1965 to 1973 Ford trucks, go to the steering section, then go to power steering section, the part is made by Scott Drake and costs $51.65, not sure if you want to pay that much, but Scott Drake has good products. https://www.npdlink.com/1948-1979-ford-truck
Regards
Regards
I have several. It all depends on the lettering, shaft diameter, and offset. Can you give more information? I might have one.
PM sent
I sent you a response and pics.
