QUESTION!!!!!!!!!!!
fourtss
QUESTION!!!!!!!!!!!
Post by fourtss »
:hmm: someone please clarify for me, c6 big block tranny, c4 small block tranny, correct or not. or can c4 be used on big block, if so why would u. :hmm: :hmm: :hmm: :? :? :?
tom
2003 ford escape
1997 dodge 1500 4wd 5speed, 1963 Cheby Corvair,
68F250
re: QUESTION!!!!!!!!!!!
Post by 68F250 »
In general that's true but there are exceptions. Some trucks and vans got a C6 behind the 302 and some cars got a C4 behind the 351M/400.
Barry
c6 is a better transmission than a c4 as i hve heard over the years. i wouldn't use a c4 if i had a c6 avaliable.
flyboy2610
Post by flyboy2610 »
The C4 can be built into a very strong tranny. If that's what you have, find a good tranny shop and have it built tough. It'll handle that 351W with no problems.
cdeal28078
Post by cdeal28078 »
There are c4's behind some very serious engines, like anything else they can be built to handle alot. Alot of the drag racers if not running a glide are running a c4. They use alot less HP to run to begin with. Are smaller and easier to fit when using headers for another. They are also pretty reasonably price on some of the parts to make them strong.
Don't sell the c4 short, it can be made to handle about anything thrown at it.
clint
71 F100 SportCustom
460 C6. Disc Brake/Power-steering/automatic Swap. 3.00
1986 Bronco 5.0 AOD
xxxtina63
Post by xxxtina63 »
Basically it all comes down to how many dollars do you want to spend and what you're going to do with it. Sure a C4 can be built strong, but the overall size of the C6 and internal components will eventually win. For light duty, a built C4 should be good. For towing, drag racing, and other heavy truck stuff, go with the C6. Remember, being overbuilt will never leave you crying over broken parts (most times).
willowbilly3
Post by willowbilly3 »
We are discussing this in another thread also. I saw some dyno figures for rear wheel horsepower on car with a slightly warmed up small block C6. It was something like 150. The C6 robs power but the low pinion of the 9 inch apparently does too.
