Brake pedal too high
Ron_Hall
Post by Ron_Hall »
Hi guys.. Since swapping to power brakes, my brake pedal seems higher off the floor. Can anyone tell me the height of theirs? ...Is it adjustable?
Ron
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
390FE1972
Re: Brake pedal too high
Post by 390FE1972 »
My truck has power disk brakes on it from the factory, and my pedal is very high as well, hopefully someone can chime in on this to give us some relief. Here are three threads that talk about pedal height from the past:
https://www.fordification.com/forum/vie ... =5&t=43043
https://www.fordification.com/forum/vie ... =5&t=38627
https://www.fordification.com/forum/vie ... =5&t=86619
Regards :thup:
pcmdub
Post by pcmdub »
My 71 F100 XLT with PB has an adjustment behind the pedal at the firewall. I adjusted the pedal height to bottom out about 1/2" before the floor and it matches the gas pedal height perfectly. My gas pedal is about 1/2" higher than stock too because I changed the linkage to fit the fuel injection manifold.
Ron_Hall
Post by Ron_Hall »
pcmdub wrote:My 71 F100 XLT with PB has an adjustment behind the pedal at the firewall. I adjusted the pedal height to bottom out about 1/2" before the floor and it matches the gas pedal height perfectly. My gas pedal is about 1/2" higher than stock too because I changed the linkage to fit the fuel injection manifold.
pcmdub, thanks for the reply. can you give a little more detail on how you adjusted it?
Also, Thanks to the other that replied :clap:
Ron
One owner...
pcmdub
Post by pcmdub »
My brake pedal has a fitting behind it to just shorten the rod. Not sure if it is stock or a previous owner welded it in but it looks factory. Here is a pic.
bellamor
Post by bellamor »
Using a pair of pliers, twist the push rod in a clockwise direction to increase the height of the brake pedal. If you need to lower the brake pedal you can do so by twisting the push rod counter clockwise.
Ron_Hall
Post by Ron_Hall »
bellamor wrote:Using a pair of pliers, twist the push rod in a clockwise direction to increase the height of the brake pedal. If you need to lower the brake pedal you can do so by twisting the push rod counter clockwise.
Is that the shaft that comes from the brake booster? Would there be enough adjustment on the stop light switch?
Ron
One owner...
pcmdub
Post by pcmdub »
Yes, it leads to the booster. For the brake light switch, you can move it, or you can add a spacer on the other side to flip the switch closed. Either works. I suggest moving it to avoid issues.
Ron_Hall
Post by Ron_Hall »
pcmdub wrote:Yes, it leads to the booster. For the brake light switch, you can move it, or you can add a spacer on the other side to flip the switch closed. Either works. I suggest moving it to avoid issues.
pcmdub, Thanks.. I was afraid of that, mine is a solid rod. I guess I could cut and thread it like that one or maybe I can buy one already made.
Thanks again
Ron
One owner...
