Tilt Wheel
goody
Tilt Wheel
Post by goody »
Hi, is there anyone who makes an aftermarket Tilt Column for a 70 F250, C-6 Automatic Column Shift. All I see is for F100's mostly Floor Shift. Also I want to keep my Neutral Safety Switch that some seem to eliminate. Thanks for your help.
basketcase0302
Re: Tilt Wheel
Post by basketcase0302 »
=goody post_id=773814 time=1646152963 user_id=8141]
Ididit probably has it but be ready to pay upwards of $800-$900 for one. :eek:
You can bolt in a dent era, (believe 78' and 79' were the only two years tilt came in the dents) that have the NSS and auto on the column like I did, if you can find one).
https://www.ididitinc.com/
96 jag ranger
Re: Tilt Wheel
Post by 96 jag ranger »
Can I use a green mustang steering wheel on my 72 explorer special the re ason I ask is a green wheel for my 72 explorer is junk and I can't find the green dye to paint a black wheel green thanks
Ferris95
Re: Tilt Wheel
Post by Ferris95 »
Hey Goody, if you are still looking for a tilt steering column, I believe NPD has what you need. I am looking at one so I can bolt up power steering without having to take out my steering shaft and cutting it shorter and welding it.
68 F-250 Ranger Camper Special 390 FE
Retired Army
Fraser
Re: Tilt Wheel
Post by Fraser »
I believe the NPD one (Saginaw) uses a GM steering wheel, fine if you want to add a custom unit.
If you use the '78-'79 truck column, you can use it's Ford wheel. A '77 or earlier wheel will not work, and an '80 column will not either, as it has an integral ignition switch.
Also, the late '70s mustang wheel will fit the '78-9 column, and was an option at the time.
