Dome light won't turn off with fuse in fuse block.
Moderators: FORDification, Thunderfoot
I went to replace the fuse for the dome light/cigar lighter on my 1970 f100 and found that there was no fuse. When I put a fuse in, the dome light is constantly on. I checked the headlight switch to make sure the dome light wasn't turned on there. I checked the door switch to see if the dome light would go off with it pushed in. I assume the previous owner pulled the fuse because the light would not go off. What can I check to fix this issue? Could it be a problem with the headlight switch itself?
My toys: 1970 F100 XLT, 302; 2018 Harley Davidson Fatbob; 2016 Toyota Tundra
Re: Dome light won't turn off with fuse in fuse block.
That would be a good place to start.
Here's a 69 wire diagram that may help.
http://www.fordification.com/tech/wirin ... lights.jpg
Or someone in the last 50 years could have cobbled something too.
Switch or door buttons, Start with switch.
1970 F250 460 C6 - Project - Currently not running.
1999 Dodge Durango SLT 4 x 4 5.9 Magnum -not running.
1999 Toyota Corolla - Daily Driver.
https://fordification.com/forum/app.php ... y/album/43
- 1972hiboy
x2
Rich
1973 f350 super c/s 460/c6 22k orig miles
1972 f350 srw crewcab special 390
1972 f250 4x4 sport custom 390fe Red
1972 f250 4x4 custom 360 FE " Ranger Ric"
1972 f250 4x4 custom 84k og miles 390
1971 f250 4x4 sport custom 56k og miles. 360
1970 f250 4x4 428 fe hp60 205 d60
Dont eat yellow snow.....
Dual post, see my reply on your other thread.
