Help with connector / wiring diagram
Charging, starting, lighting, gauges, HVAC
Moderators: FORDification, Thunderfoot
DuckRyder
Post by DuckRyder »
Any one know where this is fused and powered from? I cannot find it on the wiring diagram but it was switched power, its no longer providing switched power so it must be broken or fused somewhere besides the fuse box.
TIA for any help.
Re: Help with connector / wiring diagram
Are there any fusible links by the starter relay/ solenoid ?
DuckRyder
Post by DuckRyder »
There is one, it appears to go to the regulator via the alternator harness. I'll try to test it in the next few days...
bluef250
Post by bluef250 »
Looks like a capacitor whose purpose is to take RF to ground filtering out noise and smoothing out current. Capacitors are often seen on alternators and in distributors. Where is it connected?
https://bobistheoilguy.com/forums/threa ... do.345412/
DuckRyder
Post by DuckRyder »
It's just an empty socket, it was at one point taped to the harness. The fuse link is fine too.
bluef250
Post by bluef250 »
Did the truck have AC at one time? Electrical diagrams show a green wire with a thermostatic switch - wire 348
https://www.fordification.com/tech/wiri ... g_69ac.jpg
