69 F100 4x4 wheel question
I have a 69 F100 4x4 and am looking to change the wheels. Currently I think it sits on Ram 1500 5-lug rims and would like to swap them out. The issue is the center bore. Not sure what my front hub bore is or even how to measure it.
Re: 69 F100 4x4 wheel question
well it's dark and snowy here so all I can measure is the lock out.
It's roughly 3 1/4 inches and the wheel has some slop going over it.
The bolt spacing is 5 on 5 and a 1/2 the same from the 40's thru 1996.
old Jeeps ,Scouts and some Dodges have it also.
The aftermarket wheels have a big center hole to fit over the Jeeps and others.
I think Dodge may have a smaller hole than Ford , which is smaller than Jeep.
So almost any 5 on 5 1/2 will work.
I hope that helps.
I hope that helps.
