Breaking in rebuilt engine and transmission
Engine, ignition, fuel, cooling, exhaust
beejaytx225
Post by beejaytx225 »
Hello everyone, its been a while. I finally was able to get my 360 and my c6 rebuilt. Now ive got a bit of an issue. Both the engine and trans are still out of the truck but both need broken in. The engine requires the normal flat tappet cam break-in at 2k rpm for 20 mins and the trans needs much slower rpm (idle) to get the fluids everywhere they need to be. Basically, "Idling the engine while you run through the gears in the trans is not conducive to camshaft longevity the first time you fire a brand new motor, and running 2000 RPM for 20 min to break in the cam is not conducive to longevity the first time you spin a brand new trans." Any ideas or suggestions? Thank you
1968 F-100 Ranger LB
360 w/C6
Peacock Blue
Family nicknamed her "Bethany"
Central Texas
Past Ford's: 1994 Ranger, 2008 Ranger, 1991 Ranger, 1985 Mustang, 1968 SB Custom Cab F100, 1998 Explorer.
Current Ford's: 2011 Ranger, 2006 Expedition, and of course Bethany :)
Re: Breaking in rebuilt engine and transmission
Put it together enough to start the engine without the torque converter . then after break in put the converter in and run the tranny. ?
Or maybe you could rig up a way to spin the converter on the trans before you bolt it in to circulate the fluid. ?
It seems I had to do this once years ago and didn't know any better and just put them in and ran it , with no ill affects.
beejaytx225
Very good ideas. I'll have to ponder on the manual priming of the transmission. My concern with installing it without the torque converter is that the trans won't come out without pulling the engine back out (not really wanting to do that). Can the c6 be pulled without engine removal? Ive read the middle riveted crossmember gets in the way when pulling it back away from the motor.
360 w/C6
Peacock Blue
Central Texas
beejaytx225
I think I solved my own problem. The middle crossmember is indeed bolted in. The grease was so thick on the bolts that they appeared to be round rivets :lol:
360 w/C6
Peacock Blue
Central Texas
Fraser
Post by Fraser »
Talk to the rebuilder(s), and do what they say, They're the ones who hold the warranty. I would not run an engine without a flywheel, and I don't think the auto trans flexplate offers enough counterweight.
If nothing else, put a pump in the cooler lines and circulate the fluid as you are starting the engine, but that's just a guess.
F. Noble, Saskatchewan.
