Passenger side Air Inlet Duct
COOP3
Post by COOP3 »
Does anyone know if the clips holding the Rubber Accordion Air Inlet Duct on the passenger side are available. They look like the bottom piece of Binder Clips. Has anyone found alternatives to these clips?
1971 F250, Camper Special, 360-2V, Manual Steering, 4spd
COOP3
Re: Passenger side Air Inlet Duct
Post by COOP3 »
Here is photo of clip. I only have one, would like to get three more if possible.
jzjames
Post by jzjames »
You may find the clips are not that necessary. The rubber channel holds it on by itself
COOP3
Post by COOP3 »
You're probably right, Thanks.
Gaslight
Post by Gaslight »
I just finished mine a couple of months ago. I thought I was the first person to take it apart. But I did not have or know there were suppose to be those clips. The boot popped right on and no issues. I think you will be good.
Jake
1969 F100 Ranger
